Exhaust wrap?
Old Jul 23, 2003 | 01:44 PM
MarcGXE95's Avatar
Exhaust wrap?
I want to wrap my Y-pipe(S/S), what would be the best stuff to use?
I think the stock header is cast should I wrap it also?
Old Jul 23, 2003 | 02:12 PM
MaximaMoJo's Avatar
Any header wrap could be used. I believe that there is a write-up on www.motorvate.ca on wrapping the Y-Pipe. The header would be hard to wrap unless you took it off the engine and wrapped it.
Old Jul 23, 2003 | 02:47 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Header wrap promotes rust. Works but speeds the rusting process
Old Jul 23, 2003 | 03:05 PM
MarcGXE95's Avatar
My y-pipe is all stainless by the way!
Any one else have info on exhaust wrap?
Old Jul 23, 2003 | 07:13 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i bought some 1" wrap in the smallest length from summit racing. i believe the company was DEI. if i was going to do it over again, i would use the same product except in 2" since its easier to use.
Old Jul 23, 2003 | 07:35 PM
MarcGXE95's Avatar
I was thinking of ordering DEI (2"X50') and the spray coating. I'm still wondering if I should wrap my cast exhaust header also?
Old Jul 23, 2003 | 07:54 PM
sloppymax's Avatar
in my opinion, i wouldnt spend the time doing it. if you got some time on your hands and just feel like doing it then go for it but i dont think it would reduce underhood temps enough to make a noticeable difference but i could be wrong.
Old Jul 24, 2003 | 11:45 AM
A33 VQ30DEK's Avatar
i don't think they are doing it reduce underhood temps. they are doing it to increase the temp of the exhaust system...hotter..the exhaust gas will travel out faster.
Old Jul 24, 2003 | 01:34 PM
[maxi-overdose]'s Avatar
here is my thread on wrapping the ypipe. I did it to make EGT more stable. make sure you wear gloves, long sleeves, pants and masks. dont do it inside your garage....those fiber glass makes me felt that I just smoked a pack of cigs.
http://forums.maxima.org/showthread....haust+AND+wrap
Old Jul 24, 2003 | 01:36 PM
bigdo26's Avatar
honestly, will it keep much heat in the exhaust? i've contemplated doing the exhaust wrap numerous times, but figured it really wouldnt keep much heat in. maybe if i did the entire exhaust system, from manifold to muffler, cause i'm sure lots of heat is lost going to the muffler, but will slightly hotter temps make a hp gain?
Old Jul 24, 2003 | 07:12 PM
Nismo's Avatar
be prepared for the funny smells
Old Jul 24, 2003 | 08:24 PM
that made me hungry.....
Old Jul 24, 2003 | 11:10 PM
iansw's Avatar
Also helps hide those "bees in the can" sounds from the Y-Pipe, if you have them.
That's why I did mine.
Old Jul 25, 2003 | 06:15 AM
araffio's Avatar
Does wrapping the entire y-pipe, b-pipe and rear section up to the muffler reduce exhaust sound level at all? I'm starting a new job in a month and really would like to be a little quieter but I don't want to loose any performance...
Old Jul 25, 2003 | 06:28 AM
sloppymax's Avatar
i only have my y pipe wrapped but it really reduced the bees in the can sound that was more prevalent in hotter temperatures. if youve got a free flow muffler then i doubt the wrapping will help with sound that much that someone would actually notice.
Old Jul 25, 2003 | 06:29 AM
araffio's Avatar
Thanks...I don't have the bees in the can sound so I guess I'll leave me set up the way it is.
Old Jul 26, 2003 | 04:04 PM
ericdwong's Avatar
Yeah you guys ever remove the wrapping after its been on for a year or so? I had a cattman stainless non the less and it looked like crap after I took it off. I wouldnt waste the time money or effort. Probbly ok for the Florida guys but around here it snows and theres salt all over the roads.
Old Jul 26, 2003 | 08:03 PM
sloppymax's Avatar
i took mine off after about 2 months and it was pretty nasty even in north carolina where it hardly ever snows. it just helps with sound so much when its hot outside and i guess the exhaust expands and air is less dense.
Old Jul 28, 2003 | 09:02 PM
MaxVQ's Avatar
Let me bud in here. I'm the guy from motorvate.ca and here is what I found out:
(1) It does make the typical y-pipe hiss much quieter
(2) I don't think it makes much of a difference to under hood temps
(3) The exhaust is much hotter at the muffler than without the wrap
(4) Why would it rust? There is so much heat there, that any moisture is gone after the engine warms up. After one of the most coldest Canadian winters (lots of salt) it looks good.
My Summary:
If Nissan insulates the factory y-pipe, so will I.
-Frank.
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
jerrod99_se-l
Sep 6, 2015 08:58 PM
