New clutch installed and now shifter problems?
Well, had the act and findanza installed, then get the dealership to take that out and install a factory clutch. (This is beside the point)
So when I shift into 2nd or 4th or Reverse It will go into gear, but the shifter doesn't stop firmly, it has tones of play and feels really rubbery. I can pull it back and it continues to move, doesn't stop like it is supposed to? All the top gears are fine. Anyone have any ideas what this issue is?
Originally posted by ericdwong
Get under the car and make sure that the rod that is the shifter "support" rod is in place. It might have come unbolted. Feels just like you describe.
Originally posted by ejj
What exactly is the purpose of the support rod? Just to make sure that the transmission is the correct distance from the shifter?
Take those 3 bolts that hold it to the tranny off and you will see what it does. You cant shift w/o it. Like a brace for the shifter.
You didnt take it all the way off or you would see that you cant shift easy w/o it.
All the way off. I still do not see how it helps in shifting. I think it just keeps the transmission angled correctly.
All the way off. I still do see how it helps in shifting. I think it just keeps the transmission angled correctly.
Wayne he gots it all the way off, completely out!
vingodine
45
05-21-2016 12:46 PM
SmokinMax02
18
09-11-2015 12:25 AM
