Anyone relocated their battery to the rear?
Old Feb 6, 2001 | 02:49 PM
Dave B's Avatar
Not DAVEB the parts guy
I used the search function and couldn't find any info.
I'd think removing 40lbs of weight from the front might help the overall feel of the Max. Where exactly should I run the wires? Should I go under the car or should I go through the interior? I know I'll need a slightly heavier gauge wire because of the distance from the rear to the front. I figure I'll mount the battery behind the back seat, left side (secured in a battery box of course). Am I missing anything?
Dave
Old Feb 6, 2001 | 04:17 PM
sinewave's Avatar
I did. Here's a link to the thread.
http://forums.maxima.org/showthread....threadid=22137
So far, these 3 web sites have my files up.
http://www.geocities.com/stillnmax
http://www.maximadriver.com
http://www.geocities.com/nodoubt711
You definitely want to increase wire size to compensate for voltage drop. The factory wire is #2; I ran #2/0 because it was on sale. I didn't do voltage drop calcs, but I think that #1/0 would be more than adequate.
I put the battery on the passenger side to compensate for my phat ****.
Old Feb 6, 2001 | 05:11 PM
Lordrandall's Avatar
i30Krab did it as well, but I don't know if he has a site. I would do a search for one of his posts and look in his sig for a manufacturer.
Old Feb 6, 2001 | 10:39 PM
bullseye's Avatar
You might want to get an Optima battery if you're gonna do that. They don't have to vent. The sealed Optima battery kinda eliminates the poison gas in the trunk thing...
You should also consider fusing the line back to the trunk both front and rear, to protect against a dead short in a wreck.
You may want to run the wire from the engine compartment to the trunk inside a length of copper tubing. That will help prevent electronic noise (HUMMMMMMMMMMMM) when you turn on your stereo system.
My .02.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
