Wheel stud install Help!!!!
Old Aug 3, 2003 | 07:32 AM
Redmax's Avatar
Redlinemax Owner
Has anyone changed their wheel studs without an impact gun? is it possible? I need to fix mine quick.
Old Aug 3, 2003 | 08:10 AM
Ramius83
Yes, it is easy. You will need a FAIRLY large hammer to do it. I used a 5-pound sludge hammer. All I did was knocked it out from the front of the hub back and the bad stud fell right out. When you are placing the new one in, put it though the hole and use an open ended lug-nut and tighten it down. As you are tightening it, the lug-nut will pull the stud into the hub. Hope this helps.
Old Aug 3, 2003 | 11:03 AM
UncleMax98's Avatar
I just replaced mine. Dealer crossthreaded it, grrr. There is a cut on the brake shield that you can use to insert the new stud in. You need to rotate the hub to line up with the cut out. I also used a hammer to knock the old lug stud out. However, next time I plan to use a presser (sold at Pepboys) to push the stud out. Hammering it out may not be good for the bearing or CV joint. To pull the new stud in, you can use a few large washers and the existing lug nut.
Old Aug 3, 2003 | 12:00 PM
Nismo's Avatar
I used a ball joint removal tool to press them in and also to press them out.
Old Aug 3, 2003 | 03:13 PM
Y2KSESteve's Avatar
Anyone know how long the stock studs are?
Old Aug 3, 2003 | 03:52 PM
ZeRo MaX's Avatar
can shops/dealer do this for me? replace the stud.. i missing one.. so i have 4 lugs on....
Old Aug 3, 2003 | 05:00 PM
foodmanry's Avatar
Da Roller Coaster!
Yes, but they'll charge you about $75. It's a fairly easy job you can do yourself if you care to take the time and don't mind sweating a little.
It will only cost you $2 and some change for the stud and the half-hour or hour that it takes.
Old Aug 4, 2003 | 07:34 AM
Nealoc187's Avatar
SLOW
42mm.
Careful using the wrench method to pull the stud through. I ruined 2 studs doing that. I've had more luck just taking the extra time to hammer it 95% of the way in than trying to quickly do it with a wrench. Now if you have access to air tools then the method of just turning a lug on it to get it on is cake. I replaced all 10 in the front in about 20 minutes doing that.
Old Aug 4, 2003 | 07:53 AM
maxhead's Avatar
Re: Wheel stud install Help!!!!
Corey,
I just got your message. I didn't have my cell phone with me this weekend. Give me a call. If you haven't fixed it already, swing by tonight.
Old Aug 4, 2003 | 08:17 AM
ZeRo MaX's Avatar
i guess i an buy the studs (42mm) at any auto store?
Old Aug 4, 2003 | 10:42 AM
Y2KSESteve's Avatar
Originally posted by Nealoc187
42mm.
Thanks.
Old Aug 5, 2003 | 08:29 AM
Nealoc187's Avatar
SLOW
Yeah they are like $1.29 a piece.
dank4us
34
Jun 10, 2024 03:45 AM
Matt93SE
May 24, 2019 02:58 PM
cstrasz
Aug 27, 2015 08:07 AM
Maxima_Joe
Aug 27, 2015 12:01 AM
MikesChevelle
Aug 6, 2015 11:36 AM
