Really frustrated with the car...
Old Aug 4, 2003 | 06:42 PM
JerzMax's Avatar
My car runs like ****..it idles normal at startup, then starts to drop and I can feel the car is not running right. The rpms jump up and down, trying to stall out. Just pulled these codes out today:
0105 - Fuel INJ Sys Right bank:lean
0210 - Fuel INJ sys left bank:lean
0801 - Vacuum cut balve bypass valve
0302 - EGR System Hi/Low Flow
0702 - Three Way Catalyst (right bank)
So far I replaced the MAF (before car would start then die), replaced spark plugs, and got the fuel injectors cleaned at Midas. Why am I getting all these codes at once. Is one bad thing causing all the other codes? I'm taking the car to mechanic tomorrow, don't know what else to do.....please help.
Old Aug 4, 2003 | 06:51 PM
UMD_MaxSE's Avatar
Got Bent?
Try swapping out the fuel filter.
Old Aug 4, 2003 | 07:01 PM
Jason R's Avatar
aka UNCDooD
can i have your 3rd gear syncronizer and spring retainers out of your tranny then?
sorry to hear about your frustrations. I'm getting frustrated as well, not with the car, but with the idiots that send you fourth gear parts instead of 3rd gear parts. well, i hope everything works out for you man.
Old Aug 4, 2003 | 08:50 PM
bonzelite's Avatar
Re: Really frustrated with the car...
go here: http://forums.maxima.org/showthread....hreadid=230437
Maxman2000's Avatar
The engine's net getting enough fuel so I'd guess that it could be the fuel filter like UMD_MaxSE says or the fuel pump could be junk too.
Old Aug 4, 2003 | 11:11 PM
billy_corgan's Avatar
sounds like your POS valve is wide open
Old Aug 5, 2003 | 03:57 AM
JerzMax's Avatar
I changed the fuel filter 25,000 miles ago, does it need to be changed already?
And I did clean the IACV, it was very dirty. After cleaning it, the car did idle alot better and ran smoother till now, I'm having all these problems...
Old Aug 5, 2003 | 04:26 AM
JerzMax's Avatar
What's the POS and shouldn't I have gotten a code for that ?
Old Aug 5, 2003 | 05:36 AM
njmaxseltd's Avatar
Your running very lean.
The only item out of these that could cause that is your EGR valve. If it's sticking in the open position you will definately have symptoms like this especially after it's warmed up.
Check your EGR valve for proper operation, the whole system might need to be cleaned. You'll have to take the intake runners off in order to get at it. You might also look for the Vacuum cut bypass valve, if it's got something to do with your EGR valve, that could be causing your problem as well.
Old Aug 5, 2003 | 07:39 AM
JerzMax's Avatar
Re: Re: Really frustrated with the car...
What are the intake runners? Do you mean the intake hoses? I know the EGR is a hard place to get to, so anyone else instructions on how to remove it and clean it? Thanks.
Old Aug 5, 2003 | 01:56 PM
JerzMax's Avatar
anyone?
Old Aug 5, 2003 | 01:58 PM
think about it a little, its a joke
Old Aug 6, 2003 | 06:18 AM
JerzMax's Avatar
Now my max just shuts off when putting it in neutral at times. Is EGR the cause of this
Old Aug 6, 2003 | 06:37 AM
njmaxseltd's Avatar
I bet your EGR valve is stuck open or is leaking to much exhaust back into your intake.
Do you have a Haynes shop manual? If not, I suggest you pick one up at a local book store.
02PearlSE
Feb 1, 2016 12:37 AM
mrgooch
Sep 1, 2015 04:10 PM
MikesChevelle
Aug 9, 2015 11:50 AM
