Reverse + TQ = working tranny :)
Old Sep 3, 2003 | 09:22 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Well after some research and some thought and LOTS of frustration... I put the car in "R" and bumped the throttle until about 3400 RPM and then a thump she was rolling backwards. So I try 1st.. works as advertised.
Slow easy test drive, every gear WORKS. Med. test drive, works!
Hard test drive WORKS
SO my tranny is back to 100%.. thank goodnes.. but I can't beat on it like I have been unless I turn the boost down.
So the planning starts today.
Thanks for all the help
Old Sep 3, 2003 | 09:28 AM
MacAlert's Avatar
Time for a swap!!
Old Sep 3, 2003 | 09:53 AM
deezo's Avatar
Time for a beefier tranny.
Old Sep 3, 2003 | 12:44 PM
96shogunmax's Avatar
i should have tried that.....
na, then i wouldnt have dont the swap
Old Sep 3, 2003 | 01:06 PM
thebigsadler's Avatar
why even chance it anymore.. especially on a boosted car?
Old Sep 3, 2003 | 01:18 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Auto Transmission = Soft Vagina
5spd Transmission = Bulky Junk
Which do you have? Even beefed up auto trannies are owned by the solidity of a 5spd tranny.
Old Sep 3, 2003 | 01:31 PM
Blu's Avatar
Blu
the tits
:attention my d!ck is small but I have a 5spd
Old Sep 3, 2003 | 01:47 PM
nismo2020's Avatar
Needs non-Maxima Friends
well at least you have a heads up to start gathering your parts or try to get a hold of an auto tranny to rip apart and build up.
Old Sep 3, 2003 | 01:48 PM
Craig Mack's Avatar
yes your weiner is small and in your mind you have a 5spd.
Old Sep 3, 2003 | 01:54 PM
Blu's Avatar
Blu
the tits
keep your eyes off my package boy. Im perfectly happy with my Auto for now...
Old Sep 3, 2003 | 05:06 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Reverse doesn't count.
Neither does park or neutral incase you're.
Old Sep 3, 2003 | 05:37 PM
stephenlc's Avatar
It was probably your torque converter was getting stuck? I don't know.....
Old Sep 3, 2003 | 06:26 PM
gtr_rider's Avatar
192.168.1.1
Only time will tell
Old Sep 3, 2003 | 10:50 PM
Bags's Avatar
Hmm.. how many 5spd members have blown gears on 5spds?
Not saying anything other than if you look closely, it is hit or miss.. my situation was a miss.. but it speaks volumes that I was able to get the tranny back in working order... knocks on wood
and on which one is faster I am several other members have proven auto's are able to hang with 5spds.
deezo- beefier. yes. now, unknown.. trying to spend the money once if possible.. I am calming down... go WOT until the dhift then let off and then after the shift WOT
I wish we had the setup the supra auto's have .. the throttle plate closes during the shift no matter what postion the pedal is in
jason- I said it before and I'll say it again.. it takes time and $$ for a proper 5spd. I am aiming for 400 WHP so I am planning on that.. I do not want to blow the gears or clutch in my new 5spd doing the same thing
carl- you'll know more before most
luke-
Old Sep 3, 2003 | 11:07 PM
Jason R's Avatar
aka UNCDooD
looks like no more beating up on those EVO's huh?
with all that power I'd probably go ahead and just get a used VLSD 5-speed and rebuild. do whatever to make it stronger and more durable. depends on what you're going for though.
Old Sep 4, 2003 | 06:12 AM
mzmtg's Avatar
Minister of Silly Walks
The Nissan VLSD is pretty weak as far as diffs go. A better solution would be installing a Quaife ATB diff in a normal tranny.
Old Sep 4, 2003 | 02:35 PM
Craig Mack's Avatar
True, I have taken heed to Jeff92SE's advice to avoid being another victim of a 3rd gear blowout. I used to frequently downshift into a lower gear and pop the clutch (no revv matching) this would give the sensation of a rocket like take off and would chirp the tires, but put an extreme amount of stress on my transmission/axles. I havent done it for months now. Now I usually just get into the gear and floor it while in gear, or revv match on a downshift. If I really want that "pushed in seat" feeling, I'll get off the gas and jab it again quickly to get that chirp on take off.
Rage Maximus
Sep 3, 2015 12:26 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Supragte
Aug 12, 2015 10:00 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
kenc15
Aug 5, 2015 08:29 AM
