Turbo Kit on Ebay
Originally Posted by mzmtg
That setup sho is ugly.
Blow-through MAF...eeew.
I think it's Jime. "That Setup sho is fast".
http://forums.maxima.org/showthread.php?t=243177
Why does the blow through MAF have to go?
It's a 4th gen, MAF's aren't nearly as delicate as on 5th gens.
Plus boost/off boost transition should be smoother with a blow through MAF since it's between the throttle body and BOV. It minimizes the stumbling that can occur when the MAF is mounted upstream of the BOV. Blow through is the same way it's done on a Stillen SC. Anyone ever blown a MAF on a 4th gen with one of those?
Has a 4th gen turbo or SC setup had problems with a blow through MAF? Not that I know of. On a 5th gen it's a whole different story, but the turbo kit on eBay is a 4th gen.
And the kit is ugly because he didn't finish the pipes (or color coordinate anything). But functionally, it looks pretty decent.
Originally Posted by CullenJ76
yup jime is spraying only. and yes, the blow-thru MAF has gotta' go
Originally Posted by SprintMax
but it does make you wonder why Stillen changed the design's on their kits after
Originally Posted by Stephen Max
I know they changed it for the 5th gen kits because the 5th gen maf is much more fragile and can't handle the boost. But the 4th gen V1 and V2 kits have a blow through maf, right?
The V2 did, I had a V2 SC. It looked pretty much the same as a V1 piping wise, just the pulleys were slightly different and some other little things.
4th Gen V1 does.. i think the 4th Gen V2 doesn't
The best setup would be a draw-through MAF with a recirc valve instead of an open BOV. I hate that damn noise from the BOV anyway. I still dont understand why people try to make it as loud as possible.
You could still use a recirc valve with this setup.
Haha, I saw that too. It looks like at first they used the factory accordian section and then replaced it with a real pipe.
Originally Posted by infinitiblast
God I hope not that one picture shows some felxible autozone intake tubing..lol I dont see that holding 25 psi..
litch
123
01-04-2024 07:01 PM
220k+ A32
25
10-03-2015 09:09 PM
Pied
09-26-2015 03:29 PM
