Advance or retard timing
Old Sep 24, 2003 | 09:26 AM
Redmax's Avatar
Redlinemax Owner
For what reasons would you advance or retard timing on your car?
Old Sep 24, 2003 | 09:53 AM
SonicDust187's Avatar
Retard if you have a lot of boost or nitrous to keep teh cylinder temp down. However if you are NA you would advance the timing to create extra horsepower.
Old Sep 24, 2003 | 10:29 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i advanced my timing from 14 to 17 btdc and i noticed a bump in low end response and a little better gas mileage. it was explained to me advancing when you are NA will allow the motor to operate more efficently. i believe it does gain some in higher rpms but its so small that it is hard to be felt.
Old Sep 24, 2003 | 10:39 AM
nismology's Avatar
How did you advance your timing?? Only way you could do that is with an aftermarket chip or stand-alone engine management system.
Rob'sAE's Avatar
You're Faster, I'm Better
What if you are just mostly stock and looking for any little extra "umph" wherever you can get it? would it be benificial to me also to advance timing?
Old Sep 24, 2003 | 11:46 AM
sloppymax's Avatar
5th gens are done only through consult 2 diagnostic machine. nissan dealers use it exclusively but ive got a local nissan specific shop that purchased it from nissan and they allowed me at least one other member to use the consult ourselves and set the timing. even if you are stock, you should be able to feel a small bump in lower rpms. dont be expecting a night and day difference, its subtle but its there. if you know someone at the dealer then they might be able to set you up but otherwise people have jumped through hoops with no results from trying to get their service advisor to do it.
Old Sep 24, 2003 | 12:22 PM
I heard that once the consult 2 gets disconnected from the ecu, the ecu overrides the new timing and goes back to stock.
Old Sep 24, 2003 | 01:00 PM
][ 35's Avatar
if this is true....it sucks... i paid $50 to get my timing advanced... and it's back to normal it blows.....
Old Sep 24, 2003 | 01:49 PM
sloppymax's Avatar
not true. i actually unplugged my battery for 10hrs overnight and had the shop check it again the day following. it read 17. ive got obd-2 software that i run off my laptop which one of the parameters is timing and it shows it at 17 still. the only time it was less was in 90 degree heat when the ecu retarded it because of the temp.
Old Sep 24, 2003 | 02:37 PM
nismos14's Avatar
§è~® f®ÈÄk
if im not mistaken 4th gens can't have the timing advanced?
Old Sep 24, 2003 | 03:53 PM
You are mistaken. JWT and G-Force ECUs advance timing.
Old Sep 24, 2003 | 07:08 PM
EZEMaxima's Avatar
That's suck for us 4th gen specially for 97-99 year model. Does anybody good news for the 97-99 model?
Old Sep 25, 2003 | 02:05 AM
Blade_99SE's Avatar
I think the 99 can have there timming advanced. The ecu in the 99 is similar to the 2000+. I remember having a service tech check my codes and they had to us the newer type for the 5th gens. The 95-98 consult didn't work.
Old Sep 25, 2003 | 08:01 AM
sloppymax's Avatar
thats true as well. the tech that was watching me use the consult 2 said he had a friend with a 99 and they used the 2 for all diagnostic info so it should be able to take the timing advance as well.
Old Sep 25, 2003 | 09:04 AM
nismos14's Avatar
§è~® f®ÈÄk
i meant without an ecu upgrade lol you---> <--- me
Old Sep 25, 2003 | 09:40 AM
Thaniel's Avatar
Anybody tried modifying the crank angle sensor to change the timing?
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Starrider
Sep 17, 2015 07:26 AM
Slamrod
Sep 3, 2015 07:38 PM
rbaker100
Aug 31, 2015 11:09 AM
305head
Aug 26, 2015 09:03 PM
