When I turn my strobes on I hear something popping pretty loud.....
Old Sep 26, 2003 | 09:26 PM
Woo Cho's Avatar
everytime I turn on my strobe light I hear something popping pretty loud while my strobe is flashing. Does anybody hav this problem or anybody know wut I'm talkin about?? I got Whelen 90watt strobe kit
Old Sep 26, 2003 | 09:47 PM
geo1317's Avatar
maybe a relay??? wheres the noise comming from?
Old Sep 26, 2003 | 11:13 PM
araffio's Avatar
Mine make a very high pitched sound when each bulb flashes. Not sure if that's what you're experiencing. If it is, then that's normal. Where did you mount the control module?
-Tony
Old Sep 27, 2003 | 06:12 AM
nubiannupe's Avatar
OG Maxima.org Member
Ditto on that...
Old Sep 27, 2003 | 06:36 AM
krazyd's Avatar
you should be hearing two different noises from your strobes:
1) the tweaking noises coming from the power supply
2) the popping/ticking noises coming from the bulbs
everytime a strobe fires, the power supply and bulb will make noise at the same rate. it is normal for both of these noises to occur whenever your strobes are activated. however, depending on where you have you power supply mounted will determine whether or not you would hear these "loud" noises you are referring to. for instance if you had the power supply under your driver's seat, then you would hear the tweaking noises much better than if you had the supplies mount in your trunk. you shouldn't be able to hear the popping/ticking noises from the bulbs inside of your car. if you were outside of your car with your strobes running and put your ear up against the housing which contained a strobe bulb, you would be able to hear the bulbs doing their popping. btw, relays have nothing to do with strobes.
hope i was able to help. if you've got anymore questions, feel free to email or post them
boomerbrian
Oct 31, 2018 10:25 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
Hailstatejig
Sep 2, 2015 06:52 AM
