i think i blew a fuse...please help..
Old Feb 15, 2001 | 09:11 PM
Andrew91SE's Avatar
i was driving on the freeway with my lights on then all of a sudden my interior lights and corner lights go out...i think i blew the fuse...pretty much, when you turn on the lights, the corners, speedo, dash, and tails (not when i hit the brakes)are out...can someone please tell me where the fuse is and in which fuse box...i looked in both and really couldnt figure out which one it was? thanks a lot...
Old Feb 15, 2001 | 09:14 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Didn't Daniel and Matthel tell you your car can't handle the system in it's current state? Guess you won't learn.
Old Feb 15, 2001 | 09:28 PM
Andrew91SE's Avatar
can u please give me a helpful answer...
its not that hard...Mavica Boy!
Old Feb 15, 2001 | 09:32 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
check my reply on the "other" BBS...
Old Feb 16, 2001 | 03:36 AM
nodoubt711's Avatar
been there, done that
thats the same thing that happened to me. i have the corner light rewire mod (where they stay on all the time instead of just when you signal) and i replaced the stock corner bulb with hyper whites (which are about twice the stock wattage) and i blew my fuses twice before i changed my fuses. that little 10 amp is not going to handle it of course, i would recommend a 15 or maybe a 20. i dont remember which fuse it is exactly off the top of my head but heres a easy way to find out which one that is blown. first we know its a 10 amp. so pull out the 10 amps and look at the fuse. you can see the little metal link inside of them. if the metal link is broken then that means thats the bad fuse. i hope you can understand what i am saying.
Old Feb 16, 2001 | 11:06 AM
Ants97SE's Avatar
Look for the Taillight fuse... that controls the interior, corners, and taillights. If you did the corner light rewire mod, you probably have a 5 amp fuse in there now and it blew... best bet is it up it to a 7.5 amp fuse.
Old Feb 16, 2001 | 04:07 PM
mingo's Avatar
POP... i hate blown fuses.. means something is wrong... check for any faulty wiring in your lights.. and if the fuse u replace it with constantly pops then u really got a problem and should stop putting fresh fuses in there and have it checked out.. pop pop pop sizzle smoke burst in flames.
Old Feb 17, 2001 | 06:24 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: been there, done that
yup..exactly what you should do to burn down your car because overheated wiring. changing the fuse to 15-20 amp...great idea there. hope u have fire insurance.
Old Feb 17, 2001 | 07:46 AM
Johnny
4th gen is fuse #7
My parking lamps were out when the car was brand-new. After trips back to the Nissan dealer several times, the solution was to install a 10A fuse in place of the 7.5A. That was the solution coming from Nissan's mouth to the dealer.
Needless to say I didn't like it, but my dad whose an EE said it's ok, it's only the parking lamps/rear door pw switch lamps etc. It's been 2 1/2 years without problem.
Bump up your ratings one fuse rating at a time. Be careful to know what's on the circuit, you don't want to do that when there's electrical equipment on it, such as BOSE. But for lamps it's ok. Keep in mind I'm not saying this is true if your device is powered by a relay or fusible link (ie super high power headlamps). Good luck.
tsi6001
Oct 3, 2022 10:23 PM
jskirwin
Jun 8, 2016 08:49 AM
QueensMAX
Sep 15, 2015 04:14 AM
kjlouis
Sep 14, 2015 11:22 AM
