clunking sound from the rear!!!!
Old Oct 6, 2003 | 05:10 PM
][ 35's Avatar
The sound is very close to when u tilt or move fridge around u can hear the clunking sound.....
this sound can be only heard when i go over a bump or ruff road...
any one have experienced this kinds of sounds?
Old Oct 6, 2003 | 05:13 PM
raga55's Avatar
you might need to tighten up the jack in the trunk when its lose it will clunk around like that
Old Oct 6, 2003 | 05:37 PM
njmaxseltd's Avatar
I'll have to go tilt and move my fridge around a bit to hear what your talking about.
Old Oct 6, 2003 | 05:42 PM
][ 35's Avatar
i guess u have never moved fridge around hahaha
i have checked the jack and it's hooked on tight and don't move...
it has to do with rear shock....
Old Oct 6, 2003 | 06:01 PM
Kashoggio's Avatar
fridge huh? maybe you should take it out of your trunk hehehe check your suspension and your exhaust
Old Oct 7, 2003 | 11:15 AM
ardika's Avatar
Check your drainage tube for your sunroof. It's located near the muffler on the passenger side bumper (it looks like a little nipple if you go underneath the car).
The rubber thing that holds the hose (the end of the hose is metal) could disintegrate and leave the hose clunking (metal-to-metal).
I thought it was my license plate or my rear strut until I found out it was the tube.
But, if you don't have sunroof...don't bother.
Old Oct 7, 2003 | 12:46 PM
Asian_N02's Avatar
It could be a blown rear strut. That's what happened when my car had a clunking sound from the rear.
Old Oct 7, 2003 | 12:59 PM
MetaOrbit's Avatar
Got Projectors?
When I switched back from Teins/KYBs to stock springs/struts I heard a clunking noise in the rear - mostly when going over rough/uneven pavement.
I took it to the dealer and they replaced the left rear strut under warranty and the noise is gone.
Old Oct 7, 2003 | 01:29 PM
spirilis's Avatar
My mom's old Ford Tempo made that sound something awful after I heard a loud BANG one time on the road, got out, discovered there was hot fluid running down the left rear onto the ground that smelled vaguely like trans. fluid... it was strut oil
Over 1 year later, that car's still like that... it's hardly ever driven though
Old Oct 7, 2003 | 02:02 PM
MaxedOutOfCash's Avatar
Pizda Boy
damn, you just solved my problem. . . i always checked to see what i have in my trunk because it felt like i had something loose. . . and everytime my trunk was empty. . .darn jack was loose.
thanks
Old Oct 7, 2003 | 02:19 PM
][ 35's Avatar
how can you tell if the shock is blown? i got the KYB GR2 from a GD not to long ago.....
one more think i found out is that i can duplicate this sound by pressing up and down on the driver side rear bummer.....
does this mean the shock is blown?
Old Oct 8, 2003 | 10:18 AM
MaximaMan77's Avatar
Have you installed a RSB on the car yet?
Old Oct 8, 2003 | 10:58 AM
1BADMAX's Avatar
thanks
I believe we're a like in that when any noise comes from our cars we immedietly think the worst and usually when the real problem is discovered it ends up being nothing. We should have this done to us sometimes for always jumping to conclusions. Well on second thought maybe not.
Old Oct 8, 2003 | 11:46 AM
][ 35's Avatar
yes i do have RSB but it double check it to make sure everything is tight....
Old Oct 8, 2003 | 01:54 PM
Every thing being tight isn't the problem. As the bar travels up and down with the axel it can make contact with the pivot hinge if it is to far behind the axel. This hinge/bracket is in the center of the car a few inches behind the axle.
Check for marks in that location on the RSB and the metal on the bracket. I don't know how long ago you put it on but I would bet this is where the noise is coming from. If so you need to move the whole RSB forward until it is directly under the axle.
Old Oct 8, 2003 | 02:14 PM
Audtatious's Avatar
Bandwagon Lover
See my install page if this is an Addco-style RSB:
Click Me
The bottom mentions the clunking issue....
Old Oct 8, 2003 | 03:28 PM
Click Me
I'm barrowing one of your pic for this I hope you don't mind.
My $tillen bar made contact in a different spot.
In this pic my bar made contact going over large bumps with waht Nissan calls the lateral link & and control rod. towards the center of the car. You can see in the pic the larger lateral link that is just to the right of center. If the RSB is to far back it will also hit there.
Old Oct 8, 2003 | 05:28 PM
Audtatious's Avatar
Bandwagon Lover
Yes...If the bar is on the back side of the axle, the it could come in contact. Mine is centered with the axle so I did not have that problem.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
