Koni, sprints, and UDP installed this weekend,
Old Feb 18, 2001 | 08:40 PM
Chebosto's Avatar
RIceD OuT moDErAtor
first impressions of the UDP: Wow! the car revs ALOT faster!
this kicks ***. most noticable is the revving from 3-5k, which is my powerband due to the ecu.
Wunnnnderful
the konis went in, along with the new sprint springs.
impressions:
WOW!!!!!!!!!
my koni rears are set on stiffest setting, (full turns clockwise, and half turn back) and the fronts are full stiff, minus half turn....
its nuts! i was carving at 40 mph and the car felt SOLID. toobad my AVS intermediates were so low on tread, else i would be doing 90 + angle turns at like 60 mph.
other facts/notices.
many people have complained that the sprints in the rears are "too high" .. reason being:
the fender of the back of the car is about 1 inch lower than the front of the car, it give the illusion of "sagging" when say, you have eibachs on. well, the sprints springs keep the car slightly "level" so when you look at the fronts (3 finger gap) and the rear (also three finger gap) it looks a bit high.
in comparison, eibachs fronts are nearly 4.5 fingers, rears are 4 fingers...
i'm really happy with the performance attributes of the konis/sprints, picts will be posted in 20 minutes...
--Cheston
ps. Thanks to VBXMax, Irvine78, and Skimax for the install .
Old Feb 18, 2001 | 08:42 PM
SWEETSOUND2001's Avatar
ride quality?
Old Feb 18, 2001 | 08:44 PM
Maximamike's Avatar
Ill-matic, bro!
Old Feb 18, 2001 | 10:00 PM
Chebosto's Avatar
RIceD OuT moDErAtor
Originally posted by SWEETSOUND2001
ride quality?
on stiff / stiff, ride quality is good. a little bumpy (you can feel the inperfections in the road), but i'm used to it, (thanks to UCLA pot-holed roads)
i'd recommend the sprints to anyone who likes a nice sporty ride...
picts up soon. i'm uploading them now..
Old Feb 18, 2001 | 11:22 PM
Str8Maxin's Avatar
Spring question...
Cheston,
I'm having a hard time understanding you when you say it handles better than the eibachs. I've been told by many that progressive springs are the only way to go. Sprint are not progressive, correct? But, they handle better?
Maybe I don't want the eibachs...
Old Feb 18, 2001 | 11:56 PM
Chebosto's Avatar
RIceD OuT moDErAtor
arrrrgh
where do people get these ideas?
the sprints are PROGRESSIVE....
Old Feb 19, 2001 | 12:25 AM
mingo's Avatar
Originally posted by Chebosto
arrrrgh
cheston you park inside the ulca parking structures??? does your car clear those add on speed bumps??? man those things scare me.. the car just goes CLUNK CLUNK over them. i've been there once and decided if i'de ever attend ucla i'de get hydrolics or something (if i ever had the money)
Old Feb 19, 2001 | 06:17 AM
Max8MyCash's Avatar
Donating Maxima.org Member and Maxima.org Sponsor
YEAH CHESTON
I told you you would love those Sprints. I'm very glad you liked them...Also, I am sending you that stuff as soon as possible, I have been losing it, due to the fact I am opening the retail store at the end of the month, so I will call ya, or e-mail ya ASAP.
Alex
Old Feb 19, 2001 | 07:06 AM
Dave B's Avatar
Not DAVEB the parts guy
Cheston-
Be careful about dialing the Koni's too stiff. I'm sure you know this, but going too stiff will cause the front end to skip and slide thru the turns instead of biting. I noticed this and a few other Koni riderss noticed this. Plus I think the Koni's on their firmest setting will out dampen the springs therefore causing that cut-spring Honda bounce. For the street, 2.25 turns should be the maximum. On a road course, who knows? It depends on the track. I'm currently running 1 turn because it's so cold and the roads resemble the face of the moon right now. One pothole was so bad in Kansas City that it set off a car's airbags, blew out the front and rear glass, knocked the radio out, and tore out the suspension cross member. The car was an Accord. The pothole was 5 1/2" deep and appeared over night, probably after semi broke it up.
Dave
Old Feb 19, 2001 | 07:38 AM
_DRU_'s Avatar
height question...
ignore my ignorance but i dont know much about cars. do the konis affect the car height at all? so if i put sprint springs on my car(all stock), will it look as low as chestons? thanks
Old Feb 19, 2001 | 08:23 AM
ereet's Avatar
Naah,
as far as I know all the height of the car is done in the springs. Sprints with stock everything should look as low, BUT it'll blow your stock struts pretty quick ... (month? week? I dunno .. front ones a week, rear ones longer I'd guess).
Old Feb 19, 2001 | 08:34 AM
CoolMax's Avatar
is invisible
I doubt Cheston's car has settled yet...
only then can we determine the "real" drop.
By the way: Tokicos suck when combined with Eibachs.
Old Feb 19, 2001 | 11:44 AM
_DRU_'s Avatar
if i got sprint springs now, do you think it will last a year on stock struts? i want to drop it now but dont have enough money for the struts yet, and i also want an exhaust system. i need to prioritize... the areas i drive in have fairly good road conditions but will go to downtown on the weekends with sh1tty roads. stock struts should last at least a year, shouldnt it?
Old Feb 19, 2001 | 12:56 PM
Chebosto's Avatar
RIceD OuT moDErAtor
i put the konis on super stiff just so i can see what it's like. heh. prolly gonna dial them down to soft in the fronts, the rears are stuck there.
it handles pretty much like Skimax's coilovers , which i deem this suspension set up totally worth it...
i will have to let the car settle a bit, and will post "post-settling" drop images prolly in a month.
Max8myCash: yeah. thanks a bunch. these kick ***! tho i won't be as low as nabil's prototyped sprints, these carve just as good.
the springs out of the box are the same size as the eibachs i pulled out (the front sprints even have one more coil than eibachs) but when you put it in the car and release the jack, the car sits about 0.5 inches lower than the eibachs..
mwuahahahah.
as for speed bumps, eh. i do the usual 45 degree slant n e whoo.
the ucla parking structures here suck big time.,, now i gotta watch out for my front lip.
(which i had to remove, btw, in order to put the jack in the front .. eheh)
--cheston
Old Feb 19, 2001 | 12:58 PM
NickStam's Avatar
Damn,
I can't wait to get mine installed!!!!!!!!!
Old Feb 19, 2001 | 03:36 PM
Chebosto's Avatar
RIceD OuT moDErAtor
Re: I doubt Cheston's car has settled yet...
if you haven't seen the images of this weekend's fun,
it's at
http://www.seas.ucla.edu/~cheston/udpshox/udpshox.html
as you can see, the fronts are ever so slightly lower than eibachs (~ 1 more finger before the settling)
Old Feb 19, 2001 | 04:27 PM
black97max's Avatar
Hey Cheston
Now that your car is dropped 2 inches are you going to add caster plates to correct your alignment? Or there is no need to do so.
Old Feb 19, 2001 | 05:00 PM
1MAX2NV's Avatar
I think you mean camber plates ->
Cheston is using camber bolts which will be fine with the Sprint.
MaxLife17
Jun 27, 2019 01:37 PM
AcuraLegend
Oct 17, 2016 08:47 PM
The Wizard
24
Oct 1, 2015 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
MaxLife17
Sep 8, 2015 02:36 PM
