stereo install problem
Old Oct 24, 2003 | 07:00 PM
firsttimenissan's Avatar
I Just got my max. Its a 93 with 91k miles. The problem is.... no radio. I was going to put one of my cd players in it but there is no antenna wire. But there is a little wire with 2 prongs on it. Is that the antenna wire, or has it been cut off??? And I dont seem to be gettting enough power to run the deck, it cuts on and off. Any info would be appreciated, thanks in advance.
Old Oct 24, 2003 | 10:30 PM
ivelweyz
ask at the AUDIO forum...
Old Oct 25, 2003 | 03:41 PM
MaximusMax's Avatar
That is the antenna wire. Depending on your head-unit, you have to get an adapter kit to install it.
Old Oct 26, 2003 | 12:29 AM
kingrukus's Avatar
no more maxima...
If you aren't getting enough power to run the deck, I suggest that you run a power wire (12 guage should be ample to feed a regular head unit). Go trace out the wire, and look for the wire which powers the deck. Run a awire straight from the postive battery terminal to your deck, but make sure you fuse this wire with about a 20amp fuse close to ur battery (within 18").
Old Oct 26, 2003 | 12:34 AM
SXN's Avatar
SXN
you need an adapter/harness to run your CD player, ask the audio forum
Old Oct 26, 2003 | 06:20 PM
SEdge
well, since no one else said it, welcome to the org
Matt93SE
May 24, 2019 02:58 PM
trasmadean
Feb 1, 2017 08:20 PM
melteye
May 16, 2016 12:02 AM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
