Electrical issues help!
Old Nov 2, 2003 | 01:15 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
My car's alternator isn't charging the battery.
The battery is new, and the alternator is new... both the brand new alternator, and the old alternator read the same output 0.0
the battery reads 12.x with the car off, and doesn't go higher once the car is started. The car is running solely off the battery now.
I blew the battery fuse that is located in the engine bay, but i replaced that.
I also blew the fuse for METER in the fusebox located under the dash.
I don't have power seats, power windows, ac, my headunit does not light up... and there may be various other accessories that aren't working... i already pulled all the fuses, and the meter and battery ones are the only ones that don't work.
HELP
Old Nov 2, 2003 | 01:29 PM
Kevlo911's Avatar
Kevlo for President
the two small tiny wires htat go to alternator must be in ALL THE WAY for the system to charge. mine looked like they were in , but were not. i took a long skinny alenkey and shoved the 2 wires all the ways down into the harness. check for shorts anywere.
turbomax97's Avatar
the harness definately clicked in. where else do you suggest looking?
Old Nov 2, 2003 | 04:12 PM
slizan99's Avatar
check voltage at the alternator.
Old Nov 2, 2003 | 05:17 PM
turbomax97's Avatar
done already... 0.0 as mentioned above
Old Nov 3, 2003 | 01:41 PM
Kevlo911's Avatar
Kevlo for President
where did u get alternator from
Old Nov 4, 2003 | 08:37 AM
AllGo's Avatar
If your not getting voltage at the alt then your main fusible link between the main fuse box to the right of the battery must me blown. An alternator should get alt power at all times and has to get power from the battery to be able to send power back across this same ~10 guage wire.
Old Nov 4, 2003 | 09:43 AM
turbomax97's Avatar
autozone..... anyhoo, looks like i wasnt properly grounded on the alternator... i have a nasty drain though, enough to blow the 140A fuse for the battery... now im figuring that **** out.
Old Nov 4, 2003 | 10:00 AM
96shogunmax's Avatar
5689523237
pktaske
May 6, 2016 07:49 AM
knight_yyz
Nov 6, 2015 02:34 PM
pktaske
Sep 4, 2015 08:40 AM
