failing/clogged cat?
Old Nov 22, 2003 | 04:40 PM
JMAXIMA's Avatar
what are the signs of a clogged cat. converter? i have good reason to believe that mine is blocked so badly it is causing a leak where my ypipe/cat connection is. i have tried to fix it by replacing gaskets a couple of times... still no luck... and when i put my test pipe on.. that connection has no leak at all. and i'd leave the test pipe on, but it sounds like crap. and the car idles very badly with the cat on vs. the test pipe... it sounds like it is struggling to keep the idle... is it time for a new cat or a HF cat? i'm having a resonated cat made on monday for a temporary fix until i figure out the problem. thanks.
Old Nov 22, 2003 | 04:43 PM
nismology's Avatar
If the cat is clogged it will start glowing red hot even at idle...Look underneath the car and check...
Old Nov 22, 2003 | 04:47 PM
JMAXIMA's Avatar
i was just under there... just heard a bad leak... and let it idle for 2-3 min before the smell became too bad in my garage... but didn't turn red.... ??? are cats directional? i'm pretty certain it is in the stock position... but could i have turned it the wrong way?
Old Nov 22, 2003 | 05:00 PM
nismology's Avatar
Does it smell like rotten eggs, or sulfur?? If you smell that it could be gone. Also a loss of power, higher operating temp. than normal...But when you said you replaced the gasket and it still leaks, that gave it away. It needs to be replaced. Might as well go high flow...
Old Nov 22, 2003 | 07:33 PM
njmaxseltd's Avatar
Signs of a weak cat.....
No more purring at idle.
Hairballs found on the carpet in the morning.
Eratic behavior.
Chasing of the tail. ( usually in circles)
Chasing of the dog. (if you own one)
Bad smell from urine in the corners of your living room carpet.
And clawed apart furniture.
Does you max experiance any of these symptoms? If not then your cat is probably healthy.
Old Nov 22, 2003 | 08:31 PM
nismology's Avatar
maxinout93
Oct 31, 2015 02:04 AM
lrb6805
Sep 18, 2015 07:07 PM
Justin Kroll
Sep 2, 2015 11:06 AM
