tint question??
Old Nov 26, 2003 | 07:05 AM
sadice's Avatar
tint question??
sorry if this was asked before the search is currently down.....
i was wondering if it's ok to put tints during cold weather as it is now in NYC??? i'm talking like 32/30 F at night??? is the tint going to get ruined over nights or nothing will happen??? i know i did tints in the summer and who ever i ask from friends they did during warm times so no one know.... please if u have any info write back
thanks
Old Nov 26, 2003 | 07:09 AM
DanNY's Avatar
Ad·min·is·tra·tor
thanks
professional tint...yes no problem.
as long as the tint solution is not freezing on the glass you're fine. heat shrinking might take longer and it will definitely take longer to dry. who tints outside anyway?
off the shelf tint might not work as well. once the tint is on (properly) there's nothing to worry about. it can snow on it and it'll be ok. just don't roll down the windows for a week or so.
also warm the glass...extreme cold and extreme heat makes the glass unhappy.
Old Nov 26, 2003 | 07:11 AM
sadice's Avatar
i know about the windows had tints donw before but during summer.. ok thanx for info i apreciate it i'll probably do my tints soon than ....
Old Nov 26, 2003 | 08:42 AM
white95max's Avatar
I wouldn't have tint put on when it's near freezing. The tint adhesive is water-activated and if the water droplets between the glass and tint can't evaporate, you're gonna have bubbles forever. If those drops froze, they might stretch your tint or something. The water droplets took 2-3 days to dry on my car in sunny April.
Old Nov 26, 2003 | 08:48 AM
DanNY's Avatar
Ad·min·is·tra·tor
water activated? where did u read this? peel the liner on a piece of dry tint...it doesn't need water to have it stick on to anything.
when you tint the water is pushed out from under the flim. a professional tinter will heat the glass after tinting to get more moisture out.
where did u get your information from? are you a window tinter?
Old Nov 26, 2003 | 08:55 AM
white95max's Avatar
No I'm not a window tinter.
OK. The water is applied to remove air from between the glass and the tint. There is going to be water left over after the tint is applied to the glass. If it is below freezing, the water drops will freeze. That could not be good for the tint.
Old Nov 26, 2003 | 09:01 AM
DanNY's Avatar
Ad·min·is·tra·tor
the water/slip solution is applied so the tint can be mounted/slid in place on the window.
there is not going to be an excessive amount of water left over. a tinter will push as much water out of the tint as he/she can. after that the tinter will most likely use the heat gun to dry the tint out even more. there isn't enough residual water in the tint to cause the tint to bubble like you think it would.
well anyway...it's not the best idea to tint when it's below freezing..but it's doable.
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Redfox
Sep 28, 2015 10:41 AM
Socalstillen
Sep 26, 2015 12:01 PM
