New Custom LED Front Clearance Lights ***PICS***
Old Dec 3, 2003 | 02:56 PM
  #41
Spipedong90's Avatar
Great job!
I did my front turn signals first, because I didn't want to tackle all those LED's in the rear yet. The 12 per blinker are enough!
Old Dec 3, 2003 | 06:31 PM
  #42
Sqard's Avatar
What kit is the aluminum trim around the shifter? Looks a bit lighter than the Joshua tree kit you got on the rest.
Old Dec 3, 2003 | 07:23 PM
  #43
Mad Dhan's Avatar
looks like too many lights imo...
Old Dec 3, 2003 | 08:35 PM
  #44
ny96max's Avatar
Originally Posted by metallic97gxe
well as usual, another great mod by Mr. Tony aka MR L.E.D.
are you making these for Jason too? haha?
i should have a set of these soon, now that Tony got his car back and with 5 gears instead of 4
Ant
Old Dec 3, 2003 | 09:45 PM
  #45
Nismo98's Avatar
Originally Posted by Weasel
Looks awesome. You're not worried about the turn signals being stolen after you customize them?
No one better f*ck around with LED MAX.
Andrei
Old Dec 3, 2003 | 10:14 PM
  #46
Maxima 504's Avatar
woah that is really original.... very nice!!
Old Dec 3, 2003 | 11:28 PM
  #47
ericdwong's Avatar
Very nice. How did you attach the bulbs to the housing? Glue? Just drill a hole? Are they all wired in series? Any resistors? etc.
Old Dec 4, 2003 | 06:32 AM
  #48
Capitone's Avatar
Originally Posted by thebigsadler
Ahem "LED-King"
C.L.T. Certified LED Tech sorry....couldn't resist. Ok....tony...just two questions and Im outta your face.
1. When your wiring all this stuff together, I KNOW it's got to be pain to mount it all up THEN test it.....Im sure you don't do this sooooo....how do you test the leds out before you begin mounting stuff, you know...make sure they work. Do you use like a AA battery or something?
2. I see you go to Hofstra. Are you familiar wit Hempstead at all?
Capitone
Old Dec 4, 2003 | 09:04 AM
  #49
luckee2bhere's Avatar
Originally Posted by TofuShop
what's next? an HID dome-light?
I have one.
Old Dec 4, 2003 | 09:32 AM
  #50
gtr_rider's Avatar
192.168.1.1
How did I miss this??
Dont forget like I did, its almost your time
Old Dec 4, 2003 | 12:52 PM
  #51
Broaner's Avatar
2060lbs and falling...
What kind of amperage do that many leds draw? You must have over 200 individual leds.
Old Dec 4, 2003 | 04:07 PM
  #52
araffio's Avatar
Capitone
I don't test every single LED before mounting it, I'd be there forever. I buy them brand new so they all work without problems. Once I have them all mounted and wired (resistor on each one, wired in parallel) I just test it on the car battery to make sure all my solder joints are good to go.
I graduated from Hofstra in August and now I work in the Reckson Associates building on Merrick Ave. I can see campus from my 8th floor office
-Tony
Old Dec 4, 2003 | 04:09 PM
  #53
araffio's Avatar
The piece around the shifter is actually from Jeff (aka Shadow) and doesn't look any lighter in color in person. The direction of the "grain" on the piece goes the opposite way of my Joshua Tree kit which might make it look lighter in pics. Another piece with the correct grain direction is on its way, just put this one in temporarily...
-Tony
Old Dec 4, 2003 | 04:14 PM
  #54
araffio's Avatar
Drilled hole the right size so the LED fits in and the lip on the LED catches the edge of the hole. Hot glue where it meets the housing holds it in place for good.
Wired in parallel with resistors on each LED. Covered with rubber underbody coating for protection from the elements.
-Tony
Old Dec 4, 2003 | 04:51 PM
  #55
Brandon90gxe's Avatar
duud you have one of the cleanest maxes ive seen, im very impressed... you did the same mod with the screen as me, but your setup is ****in dope! LED tails are sick!!
Old Dec 4, 2003 | 05:59 PM
  #56
Wisky97SE's Avatar
That looks awesome . . . nice job . . . im surprised no one asked how to make em, or if you could make em.
Old Dec 4, 2003 | 11:56 PM
  #57
Maximan190's Avatar
hm new idea for tony...
HID christmas lights?
Old Dec 4, 2003 | 11:58 PM
  #58
HitManSE's Avatar
Here we go agian Looks sick & hell yeah I got in be4 it hit 1000+ posts
Old Dec 5, 2003 | 08:28 AM
  #59
thebigsadler's Avatar
Old Dec 5, 2003 | 09:40 AM
  #60
Kevlo911's Avatar
Kevlo for President
ur car is wonderful. great job on the leds.
ima try some of this as soon as my christmas break arives
Old Dec 5, 2003 | 10:22 AM
  #61
|Bijan|'s Avatar
UCF Lexus
geeezus when will you stop!!!1
Old Dec 7, 2003 | 11:51 AM
  #62
SEdge
absolutely stunning...great job
Old Dec 7, 2003 | 01:11 PM
  #63
Capital15's Avatar
Man....you are the LED king. What's next??
Old Dec 7, 2003 | 02:21 PM
  #64
araffio's Avatar
Front turn signals...
-Tony
Old Dec 7, 2003 | 02:47 PM
  #65
MyownNismo's Avatar
Future Camaro SS owner
-Tony
Wanna do my 5th gen SE tails. Just name the price.
Old Dec 7, 2003 | 03:11 PM
  #66
Iron Scimitar's Avatar
Tha Snatcher
Never ceases to amaze me...great job Tony!
Old Dec 8, 2003 | 12:08 PM
  #67
Uncle Max's Avatar
I found a basic writeup on how to wire led's to 12v but I didn't want to post it without permision from Araffio. not trying to jack his thread.
Old Dec 8, 2003 | 06:38 PM
  #68
araffio's Avatar
It's no secret on how to wire up LED's to 12v. Simple solder a resistor to the positive lead of the LED and connect 12v power and ground, you're done.
This is no secret, it's pretty much common knowledge. Wiring up the LED's is not the trick in these projects, it's gridding them out, drilling, mounting, etc.
-Tony
Old Dec 8, 2003 | 08:40 PM
  #69
SXN's Avatar
SXN
once again tony, bravo
Old Dec 8, 2003 | 08:51 PM
  #70
felix's Avatar
Sittin' On Chrome
-Tony
Tony you should make your third brake light match your tails.
Old Dec 9, 2003 | 07:31 AM
  #71
Uncle Max's Avatar
-Tony
Yea it seems pretty easy. i found some pre-drilled boards at an electronics store.
I figured it would be easy to shape the board then see where the holes are at.
Well here's the link. Someone may want to post it somewhere before the site goes down.
http://www.mmxpress.com/technical/wiringleds.htm
It kinda helps you figure out what resistor to use.
I hope this helps.
Old Dec 9, 2003 | 07:35 AM
  #72
Uncle Max's Avatar
I found a link to a supplier of LED's but I'm not sure if they're cheap or not.
I found a local supplier of those Super Brights but at 3.99 it can get expensive.
They are blinding though.
http://www.jameco.com/cgi-bin/ncomme...s=503;522;711;
Old Dec 9, 2003 | 08:06 PM
  #73
99MAXSE-L's Avatar
i bought 200 leds from some dude in hong kong
Old Dec 9, 2003 | 09:09 PM
  #74
araffio's Avatar
that guy's the best, sometimes he can be a little slow though...
-Tony
Old Dec 9, 2003 | 10:32 PM
  #75
Jr'sMaxima's Avatar
WOW.......that is HOT!!!!!!!!!!
Old Dec 10, 2003 | 06:56 AM
  #76
4DRSpeed's Avatar
Project Ruby......
Good god!! Simply amazing!
Old Dec 10, 2003 | 09:00 AM
  #77
Uncle Max's Avatar
Uhm could you post a link to your Hong Kong dude?
Oh and Araffio did I mention you rock. You're lights look great!!
Old Dec 11, 2003 | 04:18 PM
  #78
99MAXSE-L's Avatar
http://cgi6.ebay.com/ws/eBayISAPI.dl...sort=3&rows=50
heres the hong kong dude. My leds are shipped out, they take long but i guess its worth the wait. Better then buyin these leds for like 4.99 a pop at Radioshack.
Araffio...quick question, when u put orange leds for blinkers in the tails, how did they look??? are they worth buying? cuz i dont think cops like white turn signals. Anyways, do u have any pics of the orange leds?
Old Dec 11, 2003 | 04:58 PM
  #79
Uncle Max's Avatar
So the higher the MCD the brighter they are? I saw some UltraBrights at an electronic shop and were like $4 ea. I didn't know how bright they were, but it almost made me go blind when I looked directly into them.
Old Dec 11, 2003 | 04:59 PM
  #80
araffio's Avatar
I never actually put the amber leds in my blinkers. I bought them and decided to go with white before I finished the project, so the white were the first ones I put in. I'm sure they'd look decent, I just think white looks 10x cleaner and nice.
It's a matter of preference.
-Tony
