Those with 300Z Brakes, Did you Replace Caliper Bolts?
Old Dec 10, 2003 | 12:17 PM
GarthG's Avatar
Since I have replaced my brakes with 300Z brakes there is a distinct knocking/rattling from the front driver side when I first start driving the car, and then it seems after a mile it stops and all is good except under really bumpy surfaces. I originally thought that the steering knuckle wasn't ground down far enough, modified it a little more, and while some of the noise went down, sometimes it is just as loud. I used the stock Maxima cliper bolts when the calipers were replaced and these look close to the rotor and I was wondering if the 300Z bolts aren't as long as I will try that next, but need to know if they would make a difference. If anyone has any other suggestions please let me know. . .
BTW it is 93 Calipers if that makes a difference
Old Dec 10, 2003 | 01:10 PM
nupe500's Avatar
Jedi Knight
No..need to...use the stock ones.
Old Dec 10, 2003 | 02:18 PM
Lordrandall's Avatar
Nope, I used my OEM Maxima bolts.
Old Dec 10, 2003 | 06:47 PM
teejnut's Avatar
I used the Maxima ones. I heard the Z32 ones are actually longer...
Old Dec 10, 2003 | 09:36 PM
ben99sel's Avatar
me too.
Old Dec 11, 2003 | 07:49 PM
Matt93SE's Avatar
STFU n00b!
the Z32 ones are shorter... but don't worry about that. if they hold the caliper on the car, then they do their job. it's not going to make a difference which bolts you use0 just make sure you got them torqued to spec.
Old Dec 12, 2003 | 11:49 AM
GarthG's Avatar
Thanks guys. . . I think I have now traced my noises to something in the strut tower. . . strut tower moves WAY too easily. Seems like a bearing problem. . . may need to replace the bearing and see if that helps.
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
