More info on my suspension problem ->
Old Feb 27, 2001 | 05:04 PM
1MAX2NV's Avatar
ok...The spring rotates when I turn the wheel. This is the source of the noise. It's not seating correctly on the top for some reason. I took it apart and put it back on to the car again. It's still doing the same thing. and it's not the strut bearing that's causing the problem. Now this got me wonder. What part of the coil suppose to be on top and what part of the coil suppose to be on the bottom?
Here's a picture. Can someone tell which side suppose to be up and which side suppose to be down.
<img src = "http://fp.geocities.com/onemax2nv/Sprint_springs/front_sprint_vs_intrax.jpg">
[Edited by 1MAX2NV on 02-27-2001 at 07:06 PM]
Old Feb 27, 2001 | 05:09 PM
Sprint's Avatar
IIRC its smaller on the bottom so looking at that picture you have it upside down
Old Feb 27, 2001 | 05:24 PM
1MAX2NV's Avatar
From FSM, the smaller gap side should go on the bottom, but ->
On the Sprint installation sheet. It said the smaller gap is on the top. Now, I'm really confused.
Old Feb 27, 2001 | 05:27 PM
Sprint's Avatar
Re: From FSM, the smaller gap side should go on the bottom, but ->
Too the best of my knowledge the FSM way is the right way.. just try it tommorow the FSM way and see if it makes a diff..
Sprint's Avatar
wait a sec.. did you install the other side the same way? if so why doesn't it make noise on the other side? now that is strange.. make sure they are both installed that way
Old Feb 27, 2001 | 06:21 PM
1MAX2NV's Avatar
Re: Re: From FSM, the smaller gap side should go on the bottom, but ->
I did install the other side the same way and it's not making the noise on the side. That's why I don't understand it. Another thing...For a short time, the clunking noise reduced to a groin. I'm just going to drive it, maybe somehow the rubber upper isolator will seat the new spring better. If the noise persist, I'll seek professional help =) I never like suspension work. PITA.
[QUOTE]Originally posted by SprintMax
[I]wait a sec.. did you install the other side the same way? if so why doesn't it make noise on the other side? now that is strange.. make sure they are both installed that way[QUOTE]Originally posted by 1MAX2NV
[I]On the Sprint installation sheet. It said the smaller gap is on the top. Now, I'm really confused.
Old Feb 27, 2001 | 06:25 PM
Sprint's Avatar
Re: Re: Re: From FSM, the smaller gap side should go on the bottom, but ->
Good luck Tony C and take it easy... if it gets worse take it in.. we don't need that HIN fine piece of machinery damaged [QUOTE]Originally posted by 1MAX2NV
[I]I did install the other side the same way and it's not making the noise on the side. That's why I don't understand it. Another thing...For a short time, the clunking noise reduced to a groin. I'm just going to drive it, maybe somehow the rubber upper isolator will seat the new spring better. If the noise persist, I'll seek professional help =) I never like suspension work. PITA.
minsbang
Sep 11, 2015 08:48 PM
Violator
Sep 9, 2015 10:14 AM
A32goldylocks
Sep 2, 2015 06:39 AM
