What gets power while the car is turned off and locked?
Old Dec 24, 2003 | 08:03 PM
Vyrus's Avatar
Well I am 90% positive I have a short somewhere in my electrical system. When my car is off and locked and gets to sit overnight, the car will act as though it has no power at all. Nothing will work or light up. If I take off the battery terminals and reconnect them she will work perfectly, but with less power (I have a voltmeter).
Anyways I need to know what runs when the car is off. I am not thinking of anything but my security light, security LED, and my stereo's security light. Please let me know what else it could be, I am blanking out!
Thanks a lot guys,
-Cyrus
Old Dec 24, 2003 | 08:10 PM
bigdo26's Avatar
The clock keeps time, so it keeps gettin power. Radio must get a lil to keep pre-programmed stations. Thats all my ideas...
Old Dec 24, 2003 | 09:07 PM
Maxpat82's Avatar
The remote module, door lock control, got juice too
Maybe a bunch of other thing
Old Dec 24, 2003 | 10:37 PM
FanaticMadMax's Avatar
Have you check if your doors are closed compeletely? It might be the source of the drain.
Old Dec 24, 2003 | 10:41 PM
Ant96GLE's Avatar
ECU?
Old Dec 24, 2003 | 11:25 PM
Vyrus's Avatar
I've checked all the doors, battery, and fuses. Nothing seems to be wrong! I just unplugged my aftermarket alarm, and I'm hoping that's it. If it's not, I'm going to exchange my battery (thank God for Optima 3 year replacement!).
-Cyrus
Old Dec 24, 2003 | 11:57 PM
Nismo's Avatar
Alarm LED but that curcuit is intermitted not constant
Old Dec 25, 2003 | 05:18 AM
Matt_NZ's Avatar
I think the fuel pump will sometimes kick in everynow and then. At least I think it's the fuel pump, heh. Ever heard that low buzzing sound coming from the rear?
Old Dec 25, 2003 | 07:42 AM
slizan99's Avatar
what does your DVOM read at the battery after 1 minute of averything being shut off?
Old Dec 25, 2003 | 08:48 AM
Conrad283's Avatar
I need a truck
Take off the door sill and underneath the little plastic piece there is a bunch of wires. Get a tester (to see if the wire is getting juice) and then check to see if that particular wire is supposed to get juice after the car is shut off.
I had this problem with my old car when I installed my radio in there. Somehow I hooked up the radio to the clock, so the clock was pulling 12 amps or something like that
Old Dec 26, 2003 | 04:11 AM
CandiMan's Avatar
Say Candyman 5 times
Exactly, maybe your battery just isn't holding a charge. But I'll assume you've had your bettery load tested.
Old Dec 26, 2003 | 12:55 PM
Vyrus's Avatar
I'm replacing the battery today so I'll let you guys know. I'll also look into the fuel pump fuses and wires under the doorsills. Thanks a ton guys!
-Cyrus
Lakersallday24
Jun 16, 2019 01:35 AM
JRod28
Feb 4, 2016 11:07 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
acw
Aug 13, 2015 12:50 AM
kjm900r
Aug 5, 2015 07:14 AM
