1MAX2NV...q on irdium plugs
Old Sep 19, 2000 | 06:36 PM
Supa Lao's Avatar
I went to the shop that has them. He looked in the manual and gave me the IK16. I have a '97. He said the 97 take the IK20, and the 98 and 99 get he IK16. He also said the IK20 burn at a higher temp. Which one do I take? I thought the 98 and 99 have the same motor, but then why would they give 2 models of plugs.
Old Sep 19, 2000 | 07:08 PM
Matt_P
I'd go with the IK16 ->
I think the dude that used the IK20 gain 2 HP on the dyno (say 4-5 HP crank). However our car already runs fairly hot plugs. Generally you want something that is going to run reliably and remove heat from the engine. Real tuners to do not built HP through "tweaked" plugs. I am actually running NGK coppers that are 2 heat ranges colder(i'd probably be fine with 1 heat range cooler) than stock. I loose a little throttle response, but its safer for me to run more boost with the supercharger.
In all, I would not go any hotter than what the car came with. If you drive hard or have a lot of heavy mods, I would even consider something a 1 heat range down.
Matt P.
Old Sep 19, 2000 | 07:14 PM
Supa Lao's Avatar
Not a lot of mods in my car. I won't be getting a supercharger for sometime now. Gotta finish college and then pay for it
Old Sep 20, 2000 | 07:10 AM
DrewSupercharged
Ok what i know is completely different ->
I called up Denso to find out exactly what plugs we should run for our cars. The guy told me we should be running IK 16 for stock max's. I told the guy i was running 8 pounds of boost and he told me to go a step cooler and run IK 20 plugs
I was a little unsure about that so the next day i called up again and got a different service tech and he told me the same thing go with the IK 20's if your running boost. He also said the more bolts-ons you have on your car the more gains you will see from these plugs. He said NA (stock maxima) will not see much of gain with these plugs. So go figure!!!
Old Sep 20, 2000 | 07:25 AM
Supa Lao's Avatar
Thanks a lot Drew
Guess its' the IK16 for me
Old Sep 20, 2000 | 08:38 AM
1MAX2NV's Avatar
IK16 is the exact cross referance for the NGK5PF. That's what my factory manual says. Call your local nissan and find out which NGK model your car 1997 takes. If it's NGK5PF or NGK6PF. If it's the 6, you need IK20. If it's the 5 you need IK16. Good luck
Old Sep 20, 2000 | 09:10 AM
Supa Lao's Avatar
ah....
Ok, I called 2 dealers, and they gave me 2 different model numbers. 1st said the model number is PFR6G. 2nd said the model number is PFR5G11. Now I'm totall confused. I think I'll just get the IK16. The 2nd place I called sound like he knew what he was talking about.
TKHanson
Nov 24, 2018 01:39 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
