Suspension/Alignment questions.
Old Sep 20, 2000 | 01:25 AM
josh95se's Avatar
I had my car lowered with h@r springs on monday and had it aligned afterwards.
The guy who installed the springs said the car should settle another 1/2 inch. Will this affect the alignment at all?
Also, because the back end isn't adjustable, the camber is off 3%. Has this caused uneven tire wear at all for anyone? The alignment guy suggested shims to correct it but I figured 3% probly isn't enough to do too much harm.
Thanks..
Josh
Old Sep 20, 2000 | 04:28 AM
Micah95GLE's Avatar
What are your exact alignment numbers? I can compare them to mine and tell you if you should expect any problems. I haven't had any tire wear problems, by the way.
Old Sep 20, 2000 | 06:16 AM
seven's Avatar
where did you get your car aligned?
if i get one of those camber alignment kits, would i be able to realign the fronts myself. and the rears can't be adjusted at all right?
correct if i'm wrong when they realign a car after lowering their checking the camber to make sure there will be no uneven wear on the tire. if thats all then can't we do this ourselves?
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Socalstillen
Sep 20, 2015 11:46 PM
pears
Sep 18, 2015 05:25 AM
