Stock Brake Lines Vs SS Brake Lines
pedal is less spongy, better modulation of the brake pedal under hard driving... slightly better brake fade performance, since when everything gets really hot, the rubber lines will stretch more than they did before.
not hard at all , but make sure you get some good vice grips just in case when you end up with rounded off 10mm nut that connects hard lines to rubber.
and can of PB rust buster will help too.
might invest in to some speedbleeders while you there - $40 but its well worth it
bleeding the brakes took 10 minutes total.
Nick
Nick
Some of you guys that put SS lines on may have noticed a bigger improvement not becuase of the lines, but becuase of bleeding it really well so there no air bubbles and good new fluid...especially Motul 600. Make sure you bleed once a year at least. The SS will help a bit, but i would think only really at track where your fluid is gettin really hot.
Exactly. You won't notice a huge difference but the pedal feel will be a better.
Don't forget to bleed the brakes if you swap brake lines.
who makes the best ss lines????
PS: They are for a 4th gen
bbsitum
Sep 11, 2015 04:55 PM
