vibration at 80 mph, help?
Old Mar 4, 2001 | 11:25 AM
rp95se's Avatar
As I pass through 80 mph, either accelerating or decelerating, my steering wheel tends to shimmy
pretty significantly.
I have had the car in for alignment and the dealer
said that the car was within alignment specs.
Does anybody have this problem or no what it could be?
Please help?
Old Mar 4, 2001 | 11:40 AM
EZ's Avatar
EZ
Tire Balancing...
Maybe it is your tire that needs balancing. Another possible reason might be really worn struts.
EZ
Old Mar 4, 2001 | 01:57 PM
spyder
if its bad at low speed also may be Tie Rod
Old Mar 4, 2001 | 03:56 PM
Gotrice4's Avatar
Please help?
rotate your tires, if that helps u need to get those tires balanced, i did that and it rides smooth all the way to 100
Old Mar 31, 2001 | 10:26 AM
Gary95's Avatar
vibration at 80mph
I am having a similar problem when I get to 70mph. New tires, all at proper inflation, and alignment perfect.
My car is at 100k miles and has been driven very carefully (rough roads avoided, no excessive hard braking). I suspect that the struts are starting to get that normal wear. I'm going to check the manual to see the recommended mileage point at which they should be replaced. Could also be the wheel bearings, as someone else suggested.
Old Mar 31, 2001 | 10:32 AM
Kevlo911's Avatar
Kevlo for President
This may sound odd but when a got a bra for my car it ripped at the bottom and i didn't know it. the bottom part of the bra that was brokin was causing the car to vibrate. The bottom part was hitting the front bumper.
Old Mar 31, 2001 | 11:20 PM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
Purchased my Max back in Dec. Had the same problem you discribed. Dealer told me just about the same thing. After I had my stock tires replaced with new set of wheels (balanced), the problem went away.
The only conclusion I can make out of my experience is that the old set of tires needed to be balanced.
AnGe
Please help?
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
