Suspension Question --- Please Help!
Old Jan 14, 2004 | 04:34 PM
felix's Avatar
Sittin' On Chrome
I went to get an alignment today and after waiting an hour for the service guy he said he can't do it until I fix a problem.
He said I have to change my Hub Assembly on right rear tire. Can anyone explain what this is and if it's doable by yourself. He quoted me for the hub assembly like $215 and labor $97 and some cap $24. Please help me out people. Thanks a lot.
Felix
Old Jan 14, 2004 | 05:47 PM
Jatan's Avatar
That's probably the wheel bearing and hub. Here is the procedure for the front (not the rear so get a manual): http://www.motorvate.ca/mvp.php/704 I would let a shop do it to save myself the trouble, but you decide
Old Jan 14, 2004 | 07:57 PM
DanL's Avatar
The rear is MUCH easier than the front. If you can get the hub assembly (with bearings installed) the only special tool (if you want to call it that) is a big socket for the retaining nut (36 mm??). Call DaveB and see what he can do for you price wise. Or you can remove the hub yourself, buy new bearings, and pay a garage to press out the old ones and press in the new ones. The fact that the shop is only charging you one hour labor is an indication that it's not that bad a job.
Old Jan 14, 2004 | 09:54 PM
felix's Avatar
Sittin' On Chrome
So would I need the whole hub assembly or just new bearings?
Old Jan 15, 2004 | 11:50 AM
Jatan's Avatar
I'm guessing the whole hub since the guy said hub
Old Jan 15, 2004 | 01:16 PM
DanL's Avatar
Instead of guessing, just ask him what the problem was. He most likely wanted to replace the whole assembly since it was easier for him to do (doesn't have to worry about pressing the bearings out/in). I can't think of what on the hub would have gone bad.
Old Jan 15, 2004 | 01:18 PM
felix's Avatar
Sittin' On Chrome
ok, thanks for the help guys!
Old Jan 15, 2004 | 05:05 PM
DAVE Sz's Avatar
Hooooooonda.....
Before he makes a $50 allignment into a $500 job, ask for other OPINIONS. It's not like some mechanics aren't out there to screw everyone over.
Old Jan 15, 2004 | 05:08 PM
felix's Avatar
Sittin' On Chrome
i can tell there's a problem, the wheel(tire) seems to have play and sharp left turns i hear a noise. it's almost like too much pressure on that tire.
Old Jan 15, 2004 | 05:15 PM
Matt93SE's Avatar
STFU n00b!
yup, sounds like a bad wheel bearing then.. If he says it's that wheel, and you notice play in it, then there's something wrong with the bearing.
I'm not sure on 4th gens, but on 3rd gens you have to replace the entire hub- you can't replace just the bearings...
This is a 10 minute job for someone with air tools. not a hard job at all.
remove wheel, remove brake caliper, remove rotor, remove hub cap, remove hub nut, remove hub. replace.
Old Jan 15, 2004 | 05:59 PM
DanL's Avatar
I think you're right. I just looked in a Haynes manual and noticed there is no procedure for replacing just the rear wheel bearings. It does look like you replace the entire hub assembly.
Old Jan 15, 2004 | 09:20 PM
felix's Avatar
Sittin' On Chrome
anyone know where i could get a hub assembly cheaper than the shop quoted me?
Old Jan 15, 2004 | 09:27 PM
DanL's Avatar
Try calling DaveB like I suggested earlier. His number is 888-254-6060 and his
e-mail is daveb@adpub.com.
Old Jan 15, 2004 | 09:42 PM
felix's Avatar
Sittin' On Chrome
thanks Dan. I'll give him a call tomorrow. it sucks he lives so far though.
pears
Sep 18, 2015 05:25 AM
Violator
Sep 9, 2015 10:14 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
