help! i can't start my car
when i turn the key, it cranks but won't turn over. the battery is good cause the horn works. what can it poss be? i'm so confused.......
help me please.....hehehhehe thanks guys.
Crank Position (POS) has most likely failed, but pull the codes and see what you get.
If by chance you get 0505 indicating all is OK and you still get a crank but no start condition, replace crank position (POS) which is located on the bell housing under the car twards the front.
Might be a security system preventing the engine from starting. A similar problem was discussed on 5th gen forum. Check this TSB at http://maxima.theowensfamily.com/tsb/NTB99-063c.pdf
Originally Posted by twiggy144
Horn sounds does not rule out the battery. Battery may still have enough power for the horn, hell the starter needs a lot more juice.
do you hear the starter try to turn?
its 60 from nissan
http://www.trademotion.com/partlocat...97&catalogid=1
does it show any signal of barely turning over? my friends max just had same issue and his starter got worst and worst till it could barely turn over and stopped turning. Try banging on starter and seeing if it starts. If it does i think your starter is on its last leg....
Hey I have a 95 but, I had the same problem last yr and now this yr. I think that the starter should be in the same place on the 99, so it should be easy to take off, take it off and take it to auto zone and see if it has the sufficient power. I did that to mine, and guess what, my car is working.
freak! it was a low battery... good thing i have a optima red top so i just drain it and recharge it....now it's good as new
oh i let my baby sit for the last 2 months w/o stating her......shame on me.....thanks everyone for your help.
kjlouis
Nov 24, 2018 06:09 AM
kirkhilles
Aug 8, 2015 10:53 AM
