bleeding clutch
Old Jan 22, 2004 | 09:56 AM
JMAXIMA's Avatar
bleeding clutch
need some advice on bleeding my clutch... i followed the Haynes man. instructions, and it seemed liked it worked. but when i went for a test drive... the pedal became softer and softer... and then i wasn't able to engauge/disengauge the clutch w/o a lot of effort.
and if anyone knows how to adjust the pedal height/ (taking freeplay out of clutch)... again, i used the manual instruction, but i couldn't get any tool i had up there to adjust the pushrod.... any advice? thanks in advance.
-jon
Old Jan 22, 2004 | 02:21 PM
CullenJ76's Avatar
http://www.motorvate.ca/mvp.php/803
there ya go
Old Jan 22, 2004 | 02:24 PM
KLoWnPR109's Avatar
Mity Vac is your friend
Old Jan 22, 2004 | 03:43 PM
JMAXIMA's Avatar
thanks...
Haynes doesn't even mention the upper bleeder valve
Old Jan 22, 2004 | 05:53 PM
Zero Deuce SE's Avatar
Originally Posted by JMAXIMA
thanks...
That's probably because Haynes doesn't have the room to cover all the little details like the Nissan service manual does.
Old Jan 22, 2004 | 07:23 PM
Black95Se's Avatar
Do you know where I can pick up a FSM for cheap?
Ian
Old Jan 23, 2004 | 05:48 PM
CullenJ76's Avatar
especially for PS fluid.
Old Jan 23, 2004 | 06:34 PM
Ian
I don't know. I bought the FSM for my 95 KingCab from Dyment Distribution Services for $73 in 1997. At the time, the manual for a 95 Max cost $93. You might be able to find somebody selling one on eBay if you're lucky.
Old Jan 24, 2004 | 07:07 AM
pezking4's Avatar
Yeah, we couldn't find the FSM, I think it's sitting in the bottom of a closet or something. But we re-bleed the slave cylinder and did the upper this time too. Everything feels good. I love ATE super blue
Old Jan 24, 2004 | 09:03 AM
JustTry's Avatar
Is there an advantage to do this to a newer car (02 with 25k), or is this for more milaged cars, or just newly changed clutches? Basically, would I benefit from this?
Old Jan 24, 2004 | 11:06 AM
marcdown20's Avatar
basically you just need to do this if you get air in the system, if the clutch fluid gets dirty, or you just want to firm up your pedal.
mike
Old Jan 24, 2004 | 12:55 PM
skiboarder72's Avatar
I just did this to my car a few hours ago because evidently i was out of fluid
Its gotta alittle bit of play but it feels almost back to normal. I'll go play with it some more once it gets above 6 degree out..
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
