Is my clutch going? Help!
Old Mar 6, 2001 | 07:51 PM
felix_xiii's Avatar
Hey while a friend of mine was driving my car the other day he said he thinks my cluch is going. He brought to my attention that it has a lot of play, like over an inch of wiggle. Now the more I think about it, its pretty loose all around. It shifts right on the floor almost, I guess I always thought it did. Also I had the clutch replaced just over a year ago. If I have to replace it should I consider a stage 1 or maybe 2 clutch. Is it worth the $? Thanks..
Old Mar 6, 2001 | 08:39 PM
tan_camry
The main reason you may need to replace the clutch, is when you step on the gas (something like 5th gear), the tach just spins, but you're not going any faster, that's when you need a new clutch. Every clutch feels a little different from another, so you shouldn't worry about it.
Check out where I hang out also....www.pastreetracing.org.
tan
Old Mar 7, 2001 | 06:30 AM
djmaxski's Avatar
Right. Look for the tach to move but the speedometer not to, which usually means your clutch is slipping. As for it feeling loose, on some cars there are springs to adjust that control the tension on the clutch pedal. If it always felt that way to you and you don't think its slipping, then try not to worry about it.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
