opinions on split CV boots
Old Feb 24, 2004 | 11:07 AM
speakeraddict's Avatar
I have a torn outer CV boot on the drivers side of my 87SE.
The joint is fine.
Has anyone ever used a split boot?
Opinions?
speakeraddict
Old Feb 24, 2004 | 03:06 PM
BigDogJonx's Avatar
Split boots are a cheaters way out. If you tore it, you've sort of already started the damage process. Dirt gets in there and starts to destroy the joint.
Best to replace the CVboot entirely, clean the joint before that. Or just replace the whole halfshaft for about $40-50 from napa, autozone, etc.
Dixit
Old Feb 24, 2004 | 04:16 PM
FanaticMadMax's Avatar
split boot are usually a tempoary fix, but it's not intended for long term. Get your boot replace, it doesn't cost much to have it done at Pepboys or other local mechanic. They usually cost about 60 buck labor included.
Old Feb 24, 2004 | 04:46 PM
Zero Deuce SE's Avatar
I wouldn't let Pep Boys work on my lawn mower. I would take it to a good local shop that is known for quality work at a fair price.
Old Feb 24, 2004 | 04:49 PM
Dixit
If you catch it when it first happens, you can reuse the CV joint w/o any problems. The problem starts when all of the grease gets thrown out and dirt enters the joint.
Old Feb 24, 2004 | 08:36 PM
Thanks for the input guys.
I will buy OEM type boots. They are only $20 for a set of all four at O'reilly's.
I figure since the mechanic said the joints were fine, I might as well replace all the boots in one day and get it over with.
How do I clean and grease them? (Be kind, I have a ton of experience with old street rods and trucks and virtually zero with FWD cars)
Thanks again. I am sure glad my maxima owning buddy pointed me to you!
speakeraddict
Old Feb 25, 2004 | 02:39 AM
speakeraddict
You're welcome. I would compare the boots at O'reilly's with Carquest boots. The ones Carquest has are much thicker than Nissan OEM. When I had the outer boots replaced on my 92, the dealer bought Carquest boots. I wouldn't worry about cleaning all of the grease out unless you have a slovent tank. You basically clean it to inspect for wear. They sell little packs of CV joint grease at parts stores. One bag per joint. Sometimes it comes with the boots.
REDinLV
Aug 15, 2024 12:30 AM
knight_yyz
Nov 1, 2015 01:34 PM
sliptap
Sep 30, 2015 05:57 AM
londonflu
Sep 19, 2015 02:33 PM
