What is the proper way to use a floor jack?
I tried doing a search but that feature doesn't seem to be working...
Where are the proper points on the front and back to use a floor jack? I want to lift it to put on 4 jack stands to paint my calipers. Can you just put it in the center of the rear beam for the back?
Thanks.
Josh
Thanks.
Josh
Ack, no! If you want to life the whole car up, you need 4 jacks and or jack stands. the jack points are along the side of the car. The front ones are just behind the front wheels, you'll see a spot on the lower body panel where there are two notches cut out. The jack goes there with the lip of the jack going into the slots. I think on the rear there is a similar slot too, just in front of the rear wheels. There is also a little cup more inside the car underneath the body where you can set the floor jack. Don't put it anywhere else, you could put a nice bending load on a rather important part of your car, which could be bad...
Originally posted by josh95se
I've seen pics on guy's sites where they have the whole front or back up at once...so there isn't a safe or proper way to do this?
You can jack it up by the rear beam. Put the jack under the middle of the beam and jack up the back and then put your jack stands on the sides of the body then jack up the front by that crossmember that goes under the engine, etc...
I had the same problem. What I did was put a piece of wood on top of the jack and then that covered the whole bottom of the beam. Also, I just meant the middle left-to-right. Another point. With the jackstands, put them right inside the little lip on the sides of the lower body.
Originally posted by kratz74
Do a search on this. Our own Daniel B. Martin answered this question a few weeks ago. You can safely lift the entire front or rear of the car...
