Do Sprint really lower 2"????
If all you want is a low ride, then Sprint/H&R will do it. But, I think that would give you some freaky handling. The sets are designed to be used as sets. The stiff sprints in the front with the softer H&Rs in the back would give you absolutely horrible understeer at the limit. Something to think about.
you ALL know that the fender cut on the 4th gen is LOWER than the front fender. hence the "the *** is sticking up in the air" look.
so.. yeah. it might "look" higher than the eibachs, but the overall drop compared with the front and rear is lower than the eibachs.
--Cheston
--Cheston
Well, at least we won't have a rear end sag problem.....If you have koni's I think there are 2 settings for the rear....so that could possibly offest the higher rear??? I need some damn rear Koni's so I can install my suspension!!!!!!!!!!!!!!!!!
Re: Re: complainers
OEM with Sprints?
is he using a Camber Kit too? those OEM are going to die in no time.. they are no suppose to be handling a 2 inch drop.. but I could be wrong.. holy s... OEM with sprints...
Originally posted by mzmtg
I know Steve's got the OEM shocks, and I'm runnin Toks...
i blew out my stock struts with my h&rs.
i have konis now though..i kinda want to leave the *** of my car the way it is(*** in the air)cuz if it was an inch lower i'd rubb like a **** just leaving my driveway.
so i know the back is lower...
I think OEM w/ Sprints is a half - *** job. From the pic I've seen of sprint and Koni (cheston and Nabil's ) car. I don't think it's noticeable. Mabye slightly. But I def. don't want any sag in the rear. I think that looks horrible.
no no .. both of my comments were different.. i just wantd to know if you were also using a camber kit or not.. nothing to do with blowing the shocks comment
Originally posted by MaxiPad96
My car rides fine.. shocks havent blown yet... so whats the point in buying toks at this point.. i dont see one.. maybe in 10k miles or so. And what diference would it make if i had a camber kit with konis, stock, or toks... absolutley none, the camber wouldd be the same with all three
LaJolla Max
Yeah I'm at UCSD. I'm the white 4th gen with front spoiler.
In regards to all your replies thanks for all the info, and
I'm going to see if the rears settle. If the don't (I've measured before the install) then I'm going to think about
throwing on the eibach rears as a solution. No cutting springs here.
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
