Quick Foglight Question...
Old Mar 21, 2001 | 08:08 PM
_DRU_'s Avatar
my car is prewired for fogs but has no fogs. can i just buy some aftermarket ones, mount them, and splice the prewired wires and solder it on to the fogs? is that simple, or am i missing something?
Old Mar 21, 2001 | 08:43 PM
sinewave's Avatar
With the Nissan foglight kit, you also get a relay to install in the relay box under the hood and you get a new light switch/turn signal stalk. By the time you buy that, why not just install the factory fogs? They look great on the '97-'99's. IIRC,Courtesy Nissan sells the complete kit for ~$175.
Old Mar 21, 2001 | 08:50 PM
_DRU_'s Avatar
tryin to be cheap here...
so what do the prewired wires actually do? are they just there to make you want to buy the OEM foglight kit?
Old Mar 21, 2001 | 09:09 PM
sinewave's Avatar
Pre-wired means only wires. You have wires running from the foglight locations to the relay box and from the relay box to headlight switch wiring connector. The only way to effectively utilize the existing wiring is to use a Nissan relay in the relay box and a Nissan headlight switch. You can buy them separately if you like; I have no idea on the cost.
Old Mar 22, 2001 | 06:49 AM
1Phat Max's Avatar
OK
SO LET'S SAY I BUY THE RELAY AND THE NEW SWITCH FOR MY TURN SIGNAL THEN CAN I PUT AFTER-MARKET FOGS IN SUCH AS FOCUZ OR PIAA OR WHATEVER...???? CAN I JUST SPLICE INTO THE FACTORY PRE-WIRING FOR THE FOGS??? PLEASE HELP ANYONE....THANX
Old Mar 22, 2001 | 01:02 PM
Albertt's Avatar
Yes.
Fortunately, it IS that simple.
But, I would advise you to stay away from Focuz, they are not E-code auxiliary lamps. Any lamp that is, would have an "E" with a circle around it etched on the lens. PIAA unit are made well, but usually cost twice as much as others. Bear in mind, that Hella also makes good auxiliary lighting equipment.
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
