where to buy hubcentric wheel spacers with studs?
Old Apr 20, 2004 | 12:48 PM
kingrukus's Avatar
no more maxima...
Where can I find wheel spacers that are hubcentric with extended studs? It seems as if the H&R's are non existant anymore...I have a clearance issue with my new wheels that I need to fix asap because my winter tires are shot. I was also thinking of going with regular spacers, longer studs and hubcentric rings.
Old Apr 20, 2004 | 04:14 PM
Colonel's Avatar
Old Fuddy Duddy
I got mine here:
Option Auto Salon
They were in stock. Really depends on how big they need to be.
I have also heard that Ang gets them to
[/COLOR]www.redlinemax.com[/color]
Old Apr 20, 2004 | 05:10 PM
kingrukus's Avatar
no more maxima...
Originally Posted by Colonel
I got mine here:
Option Auto Salon
What size did you go with? I think I will only need 5mm....but I do not think that the 5mm come with studs...do you think longer studs are really needed with 5mm?
Old Apr 21, 2004 | 05:41 AM
Colonel's Avatar
Old Fuddy Duddy
I got the 5MM from OptAuto. I needs just a hair more clearance for my BlehmCo BBK.
I DOES come with new wheels studs.
It IS hubcentric. Almost to tight...but its not.
I was VERY impressed with the kit. It was also very easy to install as well.
Old May 2, 2004 | 10:27 AM
kingrukus's Avatar
no more maxima...
I know you said it was "easy to install"...but did this require you popping out the oem studs and replacing them with modified studs? The reason I ask is because that is what I was told by others who have had to install thicker h&r kits...I am not sure if the same rule applies to the 5mm though.
matts95max
Apr 23, 2025 10:44 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
