WHEEL Fitment Question! Help!!
Old Mar 22, 2001 | 08:21 AM
UCSDMAX
Hi,
I was wondering if a wheel with 4/114/3 & 5/114/3 (Universal) will fit the 4th gen max. Offset is 45
THanks,
Dan
Old Mar 22, 2001 | 08:27 AM
breaux124's Avatar
The bolt pattern is ok (I think)
But the offset seems high.
Old Mar 22, 2001 | 08:43 AM
Jeff92se's Avatar
I'm needing a caw
It seems okay if you have a 4 or 5-gen. Kinda depends on how wide the rims are. 7.5" or skinner is probably okay.
Old Mar 22, 2001 | 08:54 AM
1MAX2NV's Avatar
45mm should be ok. The rims are going to be more tuck in. No big brakes for you if have 45mm offset.
Originally posted by UCSDMAX
Hi,
THanks,
Dan
Old Mar 22, 2001 | 09:32 AM
CheshireCat76's Avatar
What should the offset be?
Between 35-40?
Just curious.
Old Mar 22, 2001 | 09:57 AM
breaux124's Avatar
Between 35-40?
Just curious.
Yep!
Even if it's larger than +40. You can get wheel spacers to bring it out a little.
Old Mar 22, 2001 | 11:45 AM
UCSDMAX
Thanks for all your
they helped me.
Dan
Old Jun 30, 2001 | 02:56 AM
demian's Avatar
wheel problems
I just got 18 x 7.5 wheels with 235/40 tires and 45 mm offset. I have a huge problem. The rear wheel lug nuts become loose each time I drive my car. I can't figure out why. Another problem that scares me is that the brakes make a squealing "cheep cheep" sound every time they are applied.
Also, the centercaps on the rear wheels won't fit because the brake/hub cap thing pops out the centercaps.
Does anyone have any ideas?
JoshG
21
Sep 4, 2015 09:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
