Anyone else overheating?
Old May 4, 2004 | 08:58 PM
dmontzsta's Avatar
Ford Only.
I replaced my t-stat, radiator cap and coolant last night. I was having a problem with the needle creeping up with the a/c on. I would be driving and look down and it was on the H. I would freak out, kill the a/c and pull over. I thought replacing this stuff would fix the problem. Well, tonight I was driving home on the freeway with the a/c on and it started creeping again, it got in between the normal dot and H, then I killed it and it dropped back down to normal.
What could be causing this? I cant think of anything else. I do not have any leaks.
BTW: This is with my 97.
Thanks.
Old May 4, 2004 | 09:14 PM
MrGone's Avatar
Check for cool spots in the radiator?
Also whats your coolant mix?
I'm assuming its the 97?
Do you know if your radiator fans are turning on?
kinda strange
Old May 4, 2004 | 09:45 PM
Jeff92se's Avatar
I'm needing a caw
Try bleeding your coolant system. There should be a coolant bleeder bolt somewhere. Just like the VE has.
Old May 5, 2004 | 03:49 AM
deezo's Avatar
Make sure your fans are activating like stated above. The last part of your system would be to check the water pump.
Old May 5, 2004 | 07:17 PM
SamMan23's Avatar
this may sound real basic, but check coolant level again, when the air comes out the level changes.
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
