Any tips for my suspension install tomorrow?
Old Mar 23, 2001 | 09:07 PM
NickStam's Avatar
Someone I live with an I are going to put springs in his 330i and we're gonna do my Koni's and my Sprints tomorrow if time and weather permits. We will be getting and or have:
Torque Wrench
Jack Stands
Ratchet Set
Spring Compressor
Rust Loosener Spray
What else am I forgetting? What else is not necessary but helpful?
Thanks.
Old Mar 23, 2001 | 09:12 PM
Sprint's Avatar
A proffesional?
Thanks.
Old Mar 23, 2001 | 09:16 PM
NickStam's Avatar
Thanks for nothing
Old Mar 23, 2001 | 09:17 PM
Sprint's Avatar
ok ok sorry.. get a hacksaw handy.. or a jigsaw.. because sometimes the rears get messed up and you can't get the bolt off because of the bracket over the nut and you might have to cut the metal bracket off
Thanks for nothing
Old Mar 23, 2001 | 09:21 PM
Sprint's Avatar
oh oh .. and a very good set of Vice Grips
Old Mar 23, 2001 | 09:25 PM
NickStam's Avatar
I forgot to mention that I'm gonna get pipe cutters for the Koni fronts. If I cut this bracket that you mentioned, is that going to need replacement?
Old Mar 23, 2001 | 09:29 PM
sachin98max's Avatar
just wondering how firm you're gonna keep your koni's?? im not sure what to set them at..im gettin mine installed tomorrow and don't know what to tell him. i don't plan on any autocrossing..just normal everyday driving/racing. any suggestions?
Old Mar 23, 2001 | 09:31 PM
Sprint's Avatar
nope
only if the nut is rounded up and its not holding the strut.. but hopefully you won't have this problem.. this is just a heads up
Old Mar 23, 2001 | 09:37 PM
NickStam's Avatar
I don't auto cross either. Maybe spirited driving once in a while. I think that I"m gonna go with the softest setting to begin. I can always adjust it later. That doesn't bother me.
Old Mar 23, 2001 | 09:45 PM
I30CeFiRo's Avatar
Have some white out handy. When you take out the front struts, you'll have to unscrew 3 bolts that are holding the stut/spring assembly in place. These three bolts are differnet distances apart so you can't just put it back in any way, its kinda like a puzzle. So, use the white out and mark the top of any bolt. When you put it back in, you'll know which way the three bolts are supposed to fit.
Old Mar 23, 2001 | 09:47 PM
NickStam's Avatar
Good idea!
Old Mar 24, 2001 | 04:00 AM
plrod Black 95 SE's Avatar
17mm wrench, breaker bar or a piece of pipe to fit over the 1/2 drive ratchet for leverage. use 6 point sockets and you'll be less likely to have a bolt head rounding problem
Old Mar 24, 2001 | 07:25 PM
sleeper's Avatar
stuff
Torque Wrench
Jack Stands
Ratchet Set
Spring Compressor
Rust Loosener Spray
Thanks.
a 12mm deep socket for the rear shock nuts inside the trunk. and a deep 14mm for the top of the shocks.grease.vise grips.
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 12, 2016 04:11 PM
cruce91
Sep 20, 2015 10:23 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
