Finally Did it, 2X 12" Subs w/ Stock HU!
Old May 7, 2004 | 09:48 PM
Empz's Avatar
Hey Guys,
Just wanted to say thanks to all those who answered my whole slew of questions (some of them probably stupid)
But Its finally done ... I've got Two 12" MTX subs hooked up to my stock Bose head unit! Only cost me $15 in hardware too!
Right now I'm only running one single 2 Channel Amp, but I'll be putting in a second 2 Channel Amp so I can run, each 12" bridged!
Yay!!! Now my Maxima finally bumps!!!
Pics will be coming as soon as my buddy (who took them) sends em to me!
Questions, concerns ... pass them this way ... I'll answer them to the best of my knowledge!
-E
Old May 8, 2004 | 03:31 AM
2k3TitaniumSe's Avatar
Great job! Can't wait to see the pics.
Old May 8, 2004 | 06:55 AM
kingrukus's Avatar
no more maxima...
Why did you use the stock HU? Other than for looks, I cannot really see the point.
Old May 8, 2004 | 02:16 PM
RA030726's Avatar
I'm nutty for Nissans
How did you hook up the amp to the Bose? I would like to add some real bass to my Bose set up. I just added Bose tweeters in the rear so I got the highs. It sounds pretty good now.
Old May 9, 2004 | 06:40 PM
joaquink's Avatar
¿Hablas Español?
Write up and pics are humbly requested.
Sound quality?
Old May 9, 2004 | 07:00 PM
InfinitiStyle's Avatar
Its simple...
In the trunk, splice and extend 4 wires from the + and - terminals of both rear speakers.. I forget which colors. (Its not hard to see which color wire is connected to the terminal) Then splice and extend the RED wire going to the BOSE amp under the rear speaker. (This will power up the amp, its remote turn on lead for the BOSE amp)
Go buy a RCA line convertor, which converts audio speaker wire to RCA female end connectors. Its pretty simple.. Connect the positives to the convertor.. Then the negatives.. Then run a dual male end RCA wires from the convertor to your amp (not a good idea to run the wires directly from the speakers to the amp if it supports high level input because for good bass, it requires low level sound input)
And there you go, you got audio signal to your amp! All you gotta do now is run power wire, ground, and the extended remote wire to the amp.
Old May 9, 2004 | 07:05 PM
Igor911's Avatar
IMHO- the bass will sound 100000x better with a $30 aftermarket cd player headunit. I not kid you, stock systems suck
Old May 9, 2004 | 07:12 PM
|Bijan|'s Avatar
UCF Lexus
I've got 2 12"s w/ my stock HU. But I'm planning on gettin a good aftermarket one after I pay off some debts.
Old May 10, 2004 | 05:29 AM
nycspudz03's Avatar
Hey Maxima10to1 how'd you add tweets to the rear?....I'd love to see pix
Old May 10, 2004 | 12:04 PM
RA030726's Avatar
I bought Bose front tweeters, and mounted them behind the rear speaker grills, screwed to the rear deck. You really cant see them either. I wired them to the same wires from the Bose amps that power the rear speakers. I tell you it sounds soo much better. Im not kidding, they should have come from the factory there.
Old May 12, 2004 | 03:26 PM
yeehawtex's Avatar
I pretty much wanna do the same thing as you; I want to add a little more bass to my stock bose HU and speakers. So its as easy as getting a line out converter and splicing only the rear speakers?
What do you think about the long term effects of your bose sound system? Do you think it can damage easiser with this setup? That is my main concern.
Thanks,
litch
123
Jan 4, 2024 07:01 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Sep 27, 2015 08:37 AM
