Throtle Cable Sensor cause check engine light???
Old May 11, 2004 | 10:49 AM
Ammi's Avatar
350 Detroit Muscle
Can throtle cable sensor cause check engine light to come on?
Old May 11, 2004 | 11:37 AM
DAVE Sz's Avatar
Hooooooonda.....
You mean TPS, throttle position sensor? If so then it will, but not likely unless the TPS is completely dead. My trans ECU is giving me a TPS code but not the ECU itself.
Old May 11, 2004 | 02:35 PM
Ammi's Avatar
350 Detroit Muscle
Yea I ment throtle position sensor. If you replace the engine block, does it involve removing it or you can work your way around it?
Old May 11, 2004 | 07:31 PM
DAVE Sz's Avatar
Hooooooonda.....
The TPS is the black box on the throttle body, on the right side facing the firewall. It's just 2 little screws holding it in. Keep in mind that when you remove it, you have install it with proper specs. The resistance should be around 500 ohms reading pin one on the connector.
Old May 11, 2004 | 07:35 PM
Ammi's Avatar
350 Detroit Muscle
So removal of TPS is not required when you replace your entire block?
Old May 11, 2004 | 07:41 PM
DAVE Sz's Avatar
Hooooooonda.....
You can remove it along with the throttle body. If the throttle body doesn't have to go then just leave the TPS alone. It should be in the same place on both 4th and 5th gens.
Old May 11, 2004 | 08:24 PM
Bill Brasky's Avatar
Seperated at Birth?
wow. just... wow.
removal of the wire bundle to the TPS via a connector is required when replacing an engine, yes.
removal of the TPS.... figure it out.
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
