My AC Stanks!
Old May 15, 2004 | 01:37 PM
Maximallion's Avatar
My AC Stanks!
Smells like garbage. Any ideas on why, no jokes please, I've heard it's possible to hook up air freshners right in front of the fan so that it blows goodness out your vents? Has anybody done that?
Old May 15, 2004 | 01:44 PM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showpost.ph...2&postcount=29
Old May 15, 2004 | 02:43 PM
Zero Deuce SE's Avatar
Also you want to make sure that your evaporator is draining when your AC is running. There should be some water draining from behind and to the left of the right front tire. If no water comes out after operating the AC for a period of time, the drain tube is plugged and needs to be cleaned out. It can be done with a small wire or very low pressure compressed air.
Tris1's Avatar
ditto what kevlo911 posted
Old May 16, 2004 | 03:17 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
I gotta do that, but I'm too lazy. Mine was pretty bad last year, but for some reason this year it doesn't seem too bad.
oh well.
Old May 16, 2004 | 03:21 PM
Kevlo911's Avatar
Kevlo for President
I did it before I read how to. But I pored the stuff when the car was off so it didn't do anything. lol
I will do it for real next week.
Old May 16, 2004 | 04:17 PM
5 spd's Avatar
is the drain tube up on top of the engine? or down below?
Old May 16, 2004 | 04:42 PM
Tris1's Avatar
below the engine to the left of the front right well, i believe
Old May 16, 2004 | 05:01 PM
I can't see the drain tube on my car from above. On my 95 KingCab, it's almost in the center of the firewall. It protrudes about 1½ " and bends 90º downward. You probably have to either jack your car up or put it on a lift if you cannot see the tube from the engine compartment. If you have any kind of water draining at all, you can somewhat tell the general area that it drains from by looking at the ground where it drained.
Old May 16, 2004 | 08:47 PM
5 spd's Avatar
so there is a boss/fitting/port of some kind that is always open that drains the water/condensation? or is the condensation from the outside of the tubes itself?
Old May 17, 2004 | 01:39 AM
It is normally a black rubber tube that is attached to the evaporator drain pan and protrudes through the firewall. Water that forms on the evap core drops into the pan to be drained out to the ground below.
Old May 17, 2004 | 01:50 AM
happyricefob's Avatar
V^___^V
ricer style air fresherner will solve your problem
GStrength
Mar 21, 2008 08:56 PM
Maximeltman
25
Jan 17, 2008 10:33 PM
GStrength
Oct 15, 2006 07:43 PM
