How Many Miles Can I Go With Synthetic Oil?
Old Mar 26, 2001 | 12:04 PM
1Phat Max's Avatar
I was thinking about changing my oil to synthetic. my question is how many miles/months can i go with the same oil in my engine if i changed it to sythetic(mobile 1). i have 47k miles on my car and its an automatic. please let me know about this...thanx in advance...
Old Mar 26, 2001 | 12:38 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Here are some posts
about this using the handy search feature:
http://forums.maxima.org/search.php?...der=descending
Also, viewing all of my posts in my user profile will yield a bunch of info on this as well.
The short answer is 10 to 12k on Mobile 1 for sure and 25k on Amsoil with a 12.5k interval oil filter change.
Old Mar 26, 2001 | 12:48 PM
DanNY's Avatar
Ad·min·is·tra·tor
Dr. Shing..paging Dr. Shing...
Old Mar 26, 2001 | 01:19 PM
kratz74's Avatar
This has been debated on this site several times. But in a nutshell:
-if you drive a lot and wish to extend you oil change intervals, you should consider synthetic oil,
-if you make short trips and would normally change your oil at 3 or 4,000 miles, you;d be throwing money away on synthetic (unless you wnat it for better flow at low temps).
That's it in a nutchell. MAny members have proved that sythetic oil's life, including viscosity, easily exceeds and may even double coventional oils life.
Old Mar 26, 2001 | 01:28 PM
1Phat Max's Avatar
I DRIVE LIKE 550-650 MILES PER MONTH...SO DO I NEED TO CHANGE THE OIL LIKE 3-4 MONTHS OR SHOULD I WAIT TILL I DRIVE 6-7K MILES AND THEN CHANGE IT?
Old Mar 26, 2001 | 01:31 PM
Jeff92se's Avatar
I'm needing a caw
Have you read the links yet? It's like ragu, it's in there!
Old Mar 26, 2001 | 01:46 PM
Shingles's Avatar
The missing moderator
I would disagree with the second statment. One of the benifits of synthetic is start up protection. Short trips means havint to start often... thus synthetics is good for that.
If you are going to change oil over 3k miles, however, yeah don't waste your money on synthetics.
BTW, please use the search function that this forum has provided(not you Kratz. )... there is just SOOOOO much information about this topic, having to re-type it all is just a waste of a good search engine.
-Shing
Old Mar 26, 2001 | 01:55 PM
1Phat Max's Avatar
NO BODY HAS ANSWERED ME YET
SHING I AM SORRY BUT DO YOU KNOW THE ANSWER TO MY Q? MY QUES IS I DRIVE LIKE 550-650 MILES PER MONTH...SO DO I NEED TO CHANGE THE OIL LIKE 3-4 MONTHS OR SHOULD I WAIT TILL I DRIVE 6-7K MILES AND THEN CHANGE IT? I DID TRY TO SEARCH BUT THIS TOPIC IS TOO BROAD AND I COULND FIND THE ANSWER TO MY SPECIFIC QUESTION SO IF YOU AND ANYBODY ELSE COULD HELP ME OUT, THAT WOULD BE GREAT. THANX
Old Mar 26, 2001 | 01:57 PM
Shingles's Avatar
Re: NO BODY HAS ANSWERED ME YET
First, I think you cap lock is broken... it's all caps... kinda like yelling...
second to your question... you should jsut wait for mileage... especially if on synthetic. See, they say that oil will break down over time, which is kidna true, it's the additives that can break down... but with synthetics, the stuff in there is "better" so it's pretty safe to wait for a while before changing it out.
-shing
Old Mar 26, 2001 | 02:21 PM
1Phat Max's Avatar
Re: Re: NO BODY HAS ANSWERED ME YET
thanx shing....sorry for the caps but my question had to be noticed to other ppl here and answer it if they knew about it...thanx ones again for your respose....
Old Mar 26, 2001 | 05:04 PM
Jon91SE's Avatar
Pusssseeeehhhh
well i have been using synthetic and to tell you the truth with the way i drive my car i still have to change it every 3000 or so miles, as a matter of fact i changed my oil 2 days ago and it was pretty bad in need of a change with only 3500 miles, i also gave my oil a good flush ( take tranny fluid, put in instead of oil, run car for 10 min, drain tranny fluid, then put in new oil)
Old Mar 26, 2001 | 05:11 PM
Vic's Avatar
Vic
while we're on the subject...
Dr. Shing!
should I change my synthetic oil more often (~3k) now that i have my supercharger? my mobil 1 turns pitch BLACK around 1k or so.
Thanks!
Vic
Old Mar 26, 2001 | 06:03 PM
Shingles's Avatar
If you are judging how good the oil is by color, you are DEAD wrong... remember the old say? don't judge a book by it's cover?
Let me repeat it one more time for the record:
You CAN NOT tell if the oil is good or bad by the COLOR. You simple can't.
The only way you can is by oil testing.
-Shing
Old Mar 27, 2001 | 11:05 AM
htmaxpower
when you do this
a.) is there a good brand of tranny oil to use, one that does a better job of flushing the engine? and
b.) i'm assuming you change the filter after you drain the tranny fluid, or does the flush need its own new filter which should immediately be replaced when the oil is put in?
hal
Old Mar 27, 2001 | 11:13 AM
Jon91SE's Avatar
Pusssseeeehhhh
Originally posted by htmaxpower
when you do this
hal
naw just use whatever you have around will do the job, and yes you just change the filter after you are done doing the flush....
oh yea and dont try this the other way around, oil will not flush out your tranny!!
Old Mar 27, 2001 | 11:18 AM
Jon91SE's Avatar
Pusssseeeehhhh
-Shing
i dont think i mentioned anyhting about color in my previous post..........
Old Mar 27, 2001 | 11:19 AM
htmaxpower
key...
thanks.
Old Mar 27, 2001 | 11:22 AM
Jeff92se's Avatar
I'm needing a caw
Shing's point was that there is no way to determine what the condition of the oil is just by looking. The only real way is to get it tested. Ie.. color is not an accurate indicator of the oil's condition.
The next time you change your oil, take a sample and send it to Blacksone laboratories(they can send you a kit for free but the test costs $20). They will tell you the condition of your engine. ie.. bearing wear, coolant content. This will tell you in advance if there something that's gonna go bad w/ the engine before it happens. It should also tell you if you still have the required additives in the oil also.
I know the cost of the test is close to one oil change but it's still an excellent idea to do once in awhile just to see what's going on inside the engine?
i dont think that i mentioned anything about the color of my oil in my post..............
Old Mar 27, 2001 | 11:42 AM
bill99gxe's Avatar
I just weep at
the ignorance of the board.....
Name brand oil goes at LEAST 5k, Mobile 1 at LEAST 10k, and Amsoil 25k with 12.5k filter change. If you're burning oil, etc. that's a different equation.....
If someone will ask an intelligent question, they may get an intelligent answer.
Old Mar 27, 2001 | 11:56 AM
Green 2kSE's Avatar
I don't question the ability of synthetic (and high quality dino) oil to last well beyond 3000 miles, but my concern is this: if you are a mostly city driver with short trips and if you wait until 5-6000 miles, there will be a lot of condensation and unburned fuel diluting the oil, right? For example, I drive only 3 1/2 miles each way to work. No way the car warms up enough to get rid of the moisture. Occasionally I drive 30-40 miles on weekends but I wonder if that is enough to clean up the engine. I change my oil every 3000 miles which is around 4 times a year.
Old Mar 27, 2001 | 12:02 PM
bill99gxe's Avatar
Well....
It's hard to generalize about LOW mileage, although Amsoil does throw in the "or 1 year" at the end of their 25k claims.
For someone like myself who puts 350+ miles on the car a week/20k per year, going 25k as Amsoil outlines isn't out of the question.
For someone like yourself, I would say Amsoil should be fine for one year, which would be 9k to 12k intervals.
For turbo/SC engines, Amsoil halves their claims, taking the interval down to 12k with a filter change at 6k....
What sucks is the only way to prove this is to go 3k as usual on your oil, have it analyzed, and then go 6k on the same oil and have it analyzed.....
Old Mar 27, 2001 | 12:46 PM
demian's Avatar
In response to Green 2kSE, I change my oil myself and I have noticed that there is a lot of water (condensation) that drains out. I think if you take a lot of short trips, then it would be justified to have shorter drain intervals. Water isn't known for its lubricating properties.
Old Mar 27, 2001 | 01:13 PM
brubenstein's Avatar
If this were my car, and I wanted to keep it well past 100k miles, I would change the oil 4 times a year. Even with synthetic, which is what I use.
Old Mar 27, 2001 | 01:28 PM
Jeff92se's Avatar
I'm needing a caw
Wow, you drive 100,000 miles per year?!
Old Mar 27, 2001 | 01:45 PM
bill99gxe's Avatar
Yeah,
that's more than Shing!
I'm still weeping....
markevans999
Oct 25, 2015 08:27 AM
kjlouis
Oct 3, 2015 05:29 AM
LtLeary
Sep 14, 2015 12:33 PM
pjgreek
Sep 9, 2015 09:30 PM
ag90fox
Sep 9, 2015 12:22 PM
