compressing rear calipers
I realize that I'm supposed to just turn the thing. I'm turning and turning and turning and turning and turning and .............................................
Man this takes a long time. Is this other people's experiences?
donald - bleeder valve open? I've never done that before. If you do, be sure to bleed the brakes properly afterwards
I think you mean open the master cylinder cap to releive some pressure
make sure you're turning it clockwise and it should be retracting
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
u have to turn it clockwise or counterclockwise, and make sure your ebrake isnt up and make sure your car isnt in first gear. If u turn it wrong way it will open out. I believe clockwise is the right way.
Thanks guys. I got it done. I talked to an ex-Infiniti tech today and he told me that you are supposed to lift the rubber boot that's on the caliper. I didn't do that. That could be part of the reason why it was so difficult. I hope I didn't rip em.
Also, opening the bleeder doesn't nescessarily mean you'll get air in the lines. In fact, there's a method of bleeding referred to as gravity bleeding where the bleeder is left open to allow air to rise out of it's own force. It's when you open the bleeder, press down on the pedal, and then retract the pedal, creating a vacumn while the bleeder is open that you get air in the lines. It doesn't force it's way in. Air, being less dense, naturally will rise.
Whats first gear have to do with anything?
bbsitum
09-11-2015 04:55 PM
