Blown MAF :(
Old Jun 2, 2004 | 07:50 AM
meccanoble's Avatar
Sports Button FTW
Blown MAF :(
well while cruising last night, car just got jumpity and died. It starts up perfectly but i cant rev past 2500 anymore, engine light came on, and the AFL on my SAFC shows 0.0. Its been really low recently but now its staying at 0.0. I tried driving wit filter off, same scenario...
I'm guessing blown MAF? gonna check code real quick. If it is blown MAF, where is cheapest place to get another one? and do i just need a new harness or what?
BTW, my filter is smaller than usual...wondering if that could cause this?
Old Jun 2, 2004 | 08:01 AM
meccanoble's Avatar
Sports Button FTW
ok, i got code 01 02. MAss air flow sensor. I checked and its plugged in....cant i just cut off the old sensor and put on a new one?
Old Jun 2, 2004 | 08:39 AM
NmexMAX's Avatar
dot dot dot ...
www.car-parts.com, ~ 75 dollars
Old Jun 2, 2004 | 11:34 AM
meccanoble's Avatar
Sports Button FTW
so i just have to replace the plastic part right? i spoke to a knowledgeable friend and tahts what they told me. What would cause this to go bad?! i cant believe it just went bad out of nowhere. Anything i can do to prevent this BULLSH!T?!
Old Jun 2, 2004 | 12:27 PM
meccanoble's Avatar
Sports Button FTW
ok, a friend came by with a MAF and the problem continues. I resetted the ECU and when i start the 01 02 code comes up. yes i plugged teh harness in. Speaking of which, any chance the harness may just be bad? what should i do?
Old Jun 2, 2004 | 12:31 PM
Kevlo911's Avatar
Kevlo for President
Re-ground the ground wire on the harness.
Old Jun 2, 2004 | 01:55 PM
meccanoble's Avatar
Sports Button FTW
i've tried two other MAF's, its definitely not the MAF. I am guessing its the harness cause the **** still doesnt work. I dont know how to ground the wire. I seen 3 wires, a red, yellow, and white. What should i do? Someone come help me . This car is going to nissan in the morning, i can feel it.
Old Jun 2, 2004 | 02:50 PM
VIP Maxima
damn man, problems after problems after problems for u ever since u got taht SC
Old Jun 2, 2004 | 03:59 PM
meccanoble's Avatar
Sports Button FTW
yea man, does anyone know what else to do?
Old Jun 2, 2004 | 05:59 PM
Stephen Max's Avatar
I'll bet a donut the problem is with your SAFC. Whoever installed your SAFC really should have soldered the wires to make the connections instead of using the wire splices. You were already having problem with the tach signal, which could also be caused by a bad SAFC connection at the tach wire. Or maybe it is the SAFC itself that is giving you problems.
I suggest you have somebody remove your SAFC and reconnect the maf wires (they will have been cut). Then see if things are back to normal.
Old Jun 2, 2004 | 06:23 PM
meccanoble's Avatar
Sports Button FTW
all the wires for the SAFC installed were soldered. I guess it could be an SAFC issue, but what about the harness attached to the MAF? after disconnecting harness, i sometimes pull the sensor out by the wires instead of by the head. Car has a lot of miles and i had issues with rotten wires before (harness to ecu), so i guess maybe that harness is bad too? i just dont know how to tell where its bad and where to cut....i guess this type of problem is beyond me, and i just need to go to dealer....?
Funny thing is on saturday we have a meet in the north east and i bet there's a ton of people that can fix this problem, but i wont even make it there nor can i wait....
Old Jun 2, 2004 | 06:53 PM
Hmmm. Okay I guess I owe you a donut, and my apologies to whoever wired up your SAFC.
If you're pulling on the wires to disconnect the harness, then you probably stressed the connection.
Old Jun 3, 2004 | 04:30 AM
Kevlo911's Avatar
Kevlo for President
I am pretty sure hte white wire is hte ground. Tap into it as close as you can to the harness and run a wire to a good ground point.
Old Jun 3, 2004 | 09:35 AM
meccanoble's Avatar
Sports Button FTW
*****MAJOR UPDATE AND **** RAPAGE********
I finally gave up and took it to nissan. Luckily there were no customers so i didnt have to wait a year (i hate giving up a lot of money then having to wait). Anyway, my MAF and harness are in perfect shape. You guys wont believe what the friggin problem was.
Stephen Max, i owe u an apology, and a donut . The green wire on the ecu popped off somewhere and thats why SAFC was reading 0.0 AFL and thats why MAF acted as if it was bad. I paid 200 dollars to find this small silly a$$ problem and fix it. So mad, so friggin mad. I always have the dumbest problems. Once again, this issue is not SUPERCHARGER RELATED!!!! I have yet to have any supercharger related problems, just stupid problems with wiring or other BS....
Old Jun 4, 2004 | 04:14 AM
Ummmm. Krispy Kreme....
Glad you got the problem solved, Mecca. Too bad we all don't live closer to each other, I'm sure one of us could have found the problem pretty quick without resorting to the dealer.
Old Jun 4, 2004 | 04:54 AM
nupe500's Avatar
Jedi Knight
Mecca...u always panic...stop being such a BIZNITCH!!!....lol....glad you got the issue resolve man...next time listen to advice from the org....I oughta kick you in the shins for wasting $200
Old Jun 4, 2004 | 07:34 AM
araffio's Avatar
Mecca, since you always have such dumb little problems with wire and such, you'd think by now you'd be calm when you posted this stuff. Yet you still freak out and act as though your Max has died forever. Come on bro, relax and trust that you'll be able to fix the problem
Now go out and race someone with that boost....
-Tony
Old Jun 4, 2004 | 07:41 AM
maximase86's Avatar
I love lamp.
When in doubt...blame the SAFC! ....or in some cases, the CPS!
Mecca, you should get the wiring for the ECU/SAFC cleaned up a little. I remembered the picture you posted of it before....and that was freakin scary that I was having bad nightmares!
S
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
homewrecker
Sep 24, 2015 07:01 PM
TxBroncosFan
Sep 21, 2015 06:54 PM
ballerchris510
Sep 10, 2015 09:35 PM
