How do u adjust the Ebrake?
Old Sep 24, 2000 | 08:49 PM
Chebosto's Avatar
RIceD OuT moDErAtor
after i pull the ebrake, when i get out of the car, the car will creak.
and if i push hard enough, the car will even move..
anyone have this problem?
Old Sep 24, 2000 | 08:55 PM
mingo's Avatar
i thot
the max ebrake was self adjusted.
Old Sep 24, 2000 | 10:24 PM
Eric L.'s Avatar
The ebrake is supposed to adjust itself every time you set it. Just make sure it clicks 4-6 times when you set it. I went outside just now and set my parking brake with just one click in Neutral and tried to push the car. Wouldn't budge.
Old Sep 25, 2000 | 10:43 AM
Chebosto's Avatar
RIceD OuT moDErAtor
hmmm...
i'll go play with it.. i set the ebrake and tried to move the car with the engine and wouldn't move... so that's good. maybe it was just loose that day..
thanks
Old Sep 25, 2000 | 07:20 PM
VQracer's Avatar
strange
Old Sep 25, 2000 | 07:28 PM
Lordrandall's Avatar
Check your (regular) rear brakes as well. If you need a small brake adjustment that could be your problem.
Old Sep 26, 2000 | 06:09 AM
got rice?'s Avatar
on both my Nissans, the ebrake cable can be adjusted if you jack up the car and adjust from underneath with the lock/adjust bolt to tighten/loosen the cable. the later model Max don't have this?
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
