Closed throttle position sensor.
Old Jun 28, 2004 | 07:12 AM
1MAX2NV's Avatar
Anyone ever replace it before? I got the check engine light for the second time on this. Could anything else trip this? I did tighten the throttle cables about 2 years ago. I assume is a simple swap and go type of deal.
Old Jun 28, 2004 | 08:38 PM
flashover's Avatar
the TPS?
read the FAQ noob... jk
replacing it is simple, just unscrew the two screws.
But you will need to adjust it for proper signal.
PM me if you need more info.
Old Jun 29, 2004 | 06:48 AM
1MAX2NV's Avatar
Good thing I have an used one sitting around. That's what I'm afraid of...adjusting it to get the right voltage. I like plug and play
Originally Posted by flashover
the TPS?
Old Jul 2, 2004 | 09:05 AM
flashover's Avatar
Its not bad at all, just look in the FSM for the right resistance. Its kind of fun really. You can also adjust it while its running. Dont know if its bad or not, but makes thing more interesting.
Old Jul 2, 2004 | 10:37 AM
1MAX2NV's Avatar
Those screws on the TPS is going to be hard to break loose. I don't think I can take it off without totally taking the throttle body off.
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Garrettz459
Sep 28, 2015 02:50 PM
zmcneely13
Sep 26, 2015 02:26 PM
