Fishtailed
Old Jul 1, 2004 | 01:12 PM
naijai's Avatar
Fishtailed
hey as i was leaving work today i lost all form of traction worn out tires and my rear driver driver side slammed into the curb and skipped over it no cosmetic damge but now i got the loud roar from the rear of the car dont know what it is (i know stupid me for trying to speed on wet ground ) so anyone know what it could be
Old Jul 1, 2004 | 01:14 PM
maximase86's Avatar
I love lamp.
A loud roar? Can you be more specific? I wouldn't be surprised if you knocked a wheel out of alignment or something.
S
Old Jul 1, 2004 | 01:31 PM
naijai's Avatar
the faster i go the louder it gets
Matt93SE's Avatar
STFU n00b!
FUBAR'd alignment... dead wheel bearing.. bent strut.. bent rear axle... torn bushings..
could be many things.
Old Jul 1, 2004 | 01:33 PM
naijai's Avatar
i looked at the tires from the rear and they still look straight
Old Jul 1, 2004 | 01:40 PM
naijai's Avatar
so any suggestions where to take it?
Old Jul 1, 2004 | 02:24 PM
Matt93SE's Avatar
STFU n00b!
any suspension or body shop will be able to help you out.
tell them what happened so they'll have a better idea of where to look.
Old Jul 1, 2004 | 02:29 PM
Zero Deuce SE's Avatar
I would suspect a bearing to be the roaring noise. Do not drive your car until you get it thoroughly inspected for damage to the drivetrain components.
Old Jul 1, 2004 | 03:08 PM
global_threat's Avatar
jack the rear up, take off the wheels and spin the axle. if you can hear noise, it's probably your bearings...that's what it was for me
Old Jul 1, 2004 | 04:14 PM
MrGone's Avatar
that happened to me too after my car spun. I still need to get new bearings though
spending too much time over there eh? OmGHi2U
Old Jul 1, 2004 | 10:48 PM
naijai's Avatar
man driving this car is loud as i nthe roar is loud
Old Jul 2, 2004 | 03:35 PM
did you do what i told you to do? if your bearings let go while driving, you're ganna be in a world of trouble.
Old Jul 2, 2004 | 04:56 PM
Ant96GLE's Avatar
That could be a million and one things out of spec. The roaring could be your bearing but god knows what else you could've bent up. Take it to a place where they can try to align that back end up.
Old Jul 3, 2004 | 06:28 AM
DanL's Avatar
While it probably is a bearing, it could also be a damaged tire (torn belt, bubble, blister, etc.). That's easy enough to check -- just put on your spare and see if the noise goes away.
Old Jul 3, 2004 | 07:52 PM
naijai's Avatar
will replace entire hub on monday
Old Jul 6, 2004 | 07:54 AM
naijai's Avatar
hub replaced noise gone problem solved entire cost $65;lesson learnt get a car with abs and dont speed when wet: total time taken 1hr to get the repl hub from junkyard and get it put on
MyBlue02
Jun 30, 2006 06:30 PM
EdRomo86
25
Oct 20, 2004 04:22 PM
sean05
69
Jan 28, 2004 10:40 AM
ardika
63
Dec 23, 2003 12:57 AM
99MAXSE-L
Jan 19, 2001 10:02 PM
