changing spark plugs on 1995 maxima 6cyl
Old Jul 1, 2004 | 05:19 PM
txmass's Avatar
I tried to change the spark plugs on a 1995 maxima 6 cyl. They have a metal cover with two screws, which are easy enough to take off. Then there is also an orange plastic cap covering the plug. How do you disconnect the wire and then take the plastic cap off? Is there a special tool required? Once off will I be able to reach the plug? Any tricks to avoid breaking these pieces? Thanks T
Old Jul 1, 2004 | 05:35 PM
JamesNH's Avatar
heres a link http://vbxmaxima.8m.com/sparkplug.html
all you need is skocket with extension for spark plugs allen wrench to take off cover on front back and screw driver to take off the coils. The coil wire should pull off once you push in on the button ontop of the coil
Old Jul 1, 2004 | 05:36 PM
Terran's Avatar
They should just be squeeze and pull if I remember correctly.
Old Jul 1, 2004 | 05:42 PM
mzmtg's Avatar
Minister of Silly Walks
There's no button on top of the coils...
Old Jul 1, 2004 | 06:27 PM
JamesNH's Avatar
i ment like a plastic clip or what eber you want to call it but it disconnects the wires from the coil
Old Jul 2, 2004 | 04:47 AM
Sprint's Avatar
here are my detailed pictures and write up
http://www.sprintmax.com/tails/sparkplug.htm
click on the thumbnails to make the pictures larger
Old Jul 2, 2004 | 06:18 AM
Jatan's Avatar
You're not taking out the fuel injectors are you? Follow SprintMax's instructions
Also, check out the "How To" thread at the top of the 4th gen forum
halfpol
Oct 17, 2022 12:16 PM
1992maximase30
Aug 5, 2015 09:27 PM
halfpol
Aug 5, 2015 08:24 PM
RealityCheck
Aug 5, 2015 06:18 AM
maxima297
Aug 3, 2015 12:50 PM
