Paintless Dent Repair Article
Old Apr 2, 2001 | 06:48 AM
theMax's Avatar
Taken from
http://carpoint.msn.com/jump/news/jgnews_4018966_6.asp
Using the latest technology and tools, skilled technicians can quickly remove many dents on late-model vehicles—without repainting.
With advances in PDR tools and techniques, large dents can be repaired without any body filler or repainting.
The large dent is no longer visible once the Dent Wizard technician completes the PDR process.
All new car owners dread that first dent. No matter how it happens, the first dent can make a person feel that their car will never be the same again.
Or will it?
Many dents and dings can now be repaired without a trace, when the work is performed by a skilled technician. And techniques have developed to the point that dings can be removed with the original paint in place.
Consumer Awareness Increasing
Paintless dent removal (PDR) has become widely used over the past decade by car dealers, rental agencies and auctions to prepare vehicles for resale. Yet very few consumers are aware the process exists.
Specially fabricated tools and techniques for PDR have been developed to remove dents, often up to the size of a football, from almost any body panel of a vehicle. No sanding, body filler or repainting is necessary. In most cases, when the process is complete the dent is no longer visible.
Mike Cmelik, owner of Dent Craft, Inc. in Hayden, ID, told CarPoint that PDR offers consumers convenience and quality while saving them time and money.
"The general public is not aware that paintless dent removal is even available, said Cmelik. After performing traditional auto body repair for 26 years, Cmelik's shop has focused exclusively on PDR for the past six years.
Consumers are learning about the PDR process from local dealerships and insurance companies, according to Cmelik. "In the last four to five years, insurance companies have become more aware and accepting of the PDR process, particularly to repair hail damage," Cmelik told CarPoint.
Paintless Dent Repair on the Rise
PDR is becoming more widely used, because the size of dent that can be repaired has increased over the last few years.
Bill Buckley, one of the founders of Dent Wizard, which now offers PDR services through franchises in all major U.S. cities, told CarPoint: "We have developed techniques to repair a dent the size of a football, and just a few years ago we were only repairing dents the size of a tennis ball."
The widespread use of high-strength metal and resilient paint finishes has allowed PDR to become a viable alternative to traditional body repair techniques. In fact, some insurance companies will even waive the deductible if PDR is chosen over more traditional techniques.
What Can Be Fixed
Paintless dent repair is very effective for the following situations:
from very small to large dents;
generally 1990 model year and newer vehicles;
the paint has not been broken or cracked;
the dent is not near the edge of a panel;
the panel has not had previous body repair.
PDR is so effective for hail damage that some insurance companies use "hail teams" that "chase hail." These teams travel to an area that was hit by hail to repair vehicle damage using PDR techniques.
Admittedly, not all damage to the body of a vehicle can be repaired with PDR techniques, but if a dent cannot be removed completely, often the repair will make the damage almost unnoticeable.
Advantages of Paintless Dent Repair
A number of advantages for paintless dent repair include:
no repainting or body filler needed;
less expensive than traditional body repair;
same-day service in most cases;
no risk of paint overspray on other vehicle areas;
no risk of incorrect color matching;
vehicle retains original paint.
A vehicle with original paint retains a higher value than a repainted vehicle. Even if it is just a door or a fender, it is always preferable to maintain the original paint on a vehicle for as long as possible.
How Is It Done?
PDR technicians use specialized tools to push the metal back into its original shape from behind the dent. Depending on the location of the damage, the panel is accessed by removing trim pieces, through window openings or by removing inner panels.
Ryan Snider, who performs PDR for Barrier Motors in Bellevue, WA, told CarPoint, "You need to be able to 'read the paint' to see where the dent ends and then you have to understand where the tip of the tool is. From that point it is 75 to 80 percent flat-out patience."
In a typical dent removal, the metal around the outside edge of the dent in slowly massaged back into its original position. The dent becomes progressively smaller as the technician works from the outside edge; eventually the dent becomes so small it blends with the texture of the paint and disappears completely.
Most repairs can be completed in one to two hours, and many PDR companies offer mobile service to save even more time.
Prices vary depending on the location and complexity of the repair. A general range would be $75-100 for a single dent, up to several hundred dollars to repair numerous dents on various body panels. This compares with a cost of several hundred dollars to repair and repaint a single dent using traditional auto body repair techniques.
Who Performs Paintless Dent Repair?
PDR is available from local franchises of national chains, independent shops, and some auto body repair shops or automobile dealers. A quick search of the local yellow pages or other business directories should yield several options.
As with any type of service, there can be a wide range of experience levels and work quality. So it's a good idea to check with reputable vehicle dealers—they'll know who does quality PDR work in the area.
And don't be afraid to ask for references before you have the work done, to ensure you receive the quality work you expect.
Old Apr 2, 2001 | 07:37 AM
wicked1044's Avatar
i have seen that offered at my nissan dealer.
Old Apr 2, 2001 | 07:44 AM
2ndMAX's Avatar
Hey Wicked....
What Nissan dealer did you see that at. I'm in NY and have a pretty annoying dent in my driver side front door. I'd love to have it taken care of. Please refer me to the dealer you're talking about.
Old Apr 2, 2001 | 08:20 AM
ZuMBLe's Avatar
I too have some dents I would like removed.. I guess I can put off suspension mods to make my baby look pretty again. =)
ZuM
Old Apr 2, 2001 | 11:36 AM
wicked1044's Avatar
Newburg nissan, its farrr..
just call a few places in your phone book and ask if they do it....you might find a place 10 min away......
Old Apr 2, 2001 | 12:03 PM
kratz74's Avatar
WARNING
It takes some experience to perform PDR well. I used to work for an insurer who used this method quite a bit. SOme vendors are excellent while other are not so good. They won;t further damage your car BUT they may not get the dent(s) completely out of the metal and still want full price. Get references or ask for an example of their work or watch them take a few dents out...
The reputable guys will tell you when they cannot get a dent out. My MAx got severe hail damage and the PDR guys told me they could not fix it.
Old Apr 2, 2001 | 12:51 PM
pmar's Avatar
excellent excellent point
Remember, PDR is for the masses, 90% of the population. I'd guess that less than 1% of all Max owners are on this bbs, so I say IMHO PDR is NOT for you if you're reading this post.
I saw a 2001 Max leaving work today and it was obvious the rear door was repaired. Sometimes I wonder how owners can put up with body work. But the truth is the avg person could care less. They probably lease the car anyway. It usually isn't the paint that gives it away, paint matches pretty nicely. But when the car is clean the bondo is like a sore thumb--it's not like a mirror, it's very ripply.
I had hoped PDR could fix a ding. The guy said up front he had his doubts as it was along a line under my rear window. He made it worse in my opinion, and I didn't pay him. He agreed and left it up to me whether I would pay the $80.
It's not about getting behind the ding--the dent man has so many rods there is no way he will be unable to get behind it. But it takes much more force than most people think to put the dent in the body--it takes just as much to remove it. Problem is you can't precisely line up the tool. They rely on lamps and mirrors and try. Again, if you're 90% of the population you may be satisfied. But if you're an enthusiast you'll be disappointed as I was.
mkaresh
Mar 12, 2018 06:48 PM
Turbonut
46
Oct 21, 2015 08:28 PM
MichMaxFan
Sep 30, 2015 09:18 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
dcam0326
Sep 8, 2015 11:02 PM
