Blue #194 Bulbs
Ok, after installing my new BLUE APC #194 bulbs into my guages the other week, they are already starting to fade. I have been looking around and cannot find another bulb from another manufacturer that I could use that would be worth replacing the existing bulbs. Does any one know of a GOOD buld that will not fade and is an actual blue and not a teal color like the APCs. Thanks
Originally posted by WizzaMax
Use Polarg...they have a much nicer and longer lasting color.
www.autofreak.net has a few different brands in blue. I have the raybrigs and they look pretty good.
Originally posted by maxse91
im not to sure what they are called but some import shops carry these little "light bulb condoms"
that go over a light and since the sleeve is colored your light is colored, cheap alternative
I'd rather go this route, because the blue colored bulbs are probably not the right color and they might fade over time.
When upgrading to #194, do you have up bump up the fuse amperage? (e.g. from 7.5 to 10)
I'm assuming by your screenname that you have a 95 Max. A 95 Max already has 194 bulbs with blue sleeves in the gauge cluster. So there's no need to up the fuse.
Originally posted by Gary95
I30CeFiRo said he replaced his I30 gauges with the Indiglo kit. When he removed the bulbs, he noted that they had blue sleeves over them. So, the question is what brand of bulb does Infinity use and can you buy the blue sleeves from them. Maybe there is an aftermarket sleeve you can get that matches, for a reasonable price.
#194 is just the size--I meant to say that when upgrading to a more powerful bulb of that size, do you need to change the fuse. Well, I'll find out soon enough. I'm going to order the Eurolite Crystal Whites. The folks there said it is a high intensity whitish blue. Sounds like the I30 gauge look I've been searching for.
Originally posted by Soon2BMaxed
hey ramius, i thought about putting blue 194s behind my guages but i didn't know if it would look good or not, so how did it look (before they faded)?
Trust me... there's a blue sleeve. I've messed around with my gauges enough times - changing the lights, putting in indiglos, taking them out... there are blue sleeves. And yes, you're right, they certainly don't give the bulb a blue tint.
I have a 95 Max SE. There couldn't be blue sleeves over the bulbs--the light is pure white.
It's weird then, isn't it? I guess the tint just isn't strong enough. So, it looks like a toss up between Polarg and Eurolites... The AIEonline folks said the Eurolites give off a bright white with a hint of blue, probably close to what I'm looking for. Anyway, I'm going to bug the Infinity folks to find out details on their bulbs and/or sleeves.
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
