Replacing rear oxygen senor with resistors, like the knock sensor resistor mod.
Old Jul 30, 2004 | 04:51 PM
95CustomMaxima's Avatar
My rear o2 sensor has died on me and I dont have the money right now to replace it. My friend was saying on his forums (DSMtuners.com) you can replace it with resistors, like we do with the knock sensors here. I am wondering if this would be possible with our rear o2 sensor? I mean the rear o2 sensor only detects whether the cat is working or not correct. So by using resistors we would just be tricking the computer into thinking it is working. Any ideas or any experience with this would be very helpful and greatly appreciated.
Thanks,
-Nick
Old Jul 30, 2004 | 05:34 PM
Nismo's Avatar
I been wanting to do this too. Anyone know what resistance should a working o2 be at?
Old Jul 30, 2004 | 05:56 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
check this link HERE its only 30 shipped and you woudlnt have to worry about rigging up your own setup.
Old Jul 30, 2004 | 07:46 PM
Nismo's Avatar
pretty cool, I might check that out
Old Jul 30, 2004 | 08:38 PM
Jime's Avatar
Resistors will not work, the ecu must sense a varying voltage thats why a o2 simulator must be used.
I got mine from the place sloppymax is showing, easy hookup and no lights since installation about 3 months ago.
Old Jul 31, 2004 | 12:20 AM
I_EaT_RiCe_ErZ's Avatar
I guess I'll be looking into that too. Can a bad rear o2 sensor trigger the knock sensor 0304 code also? I have both codes. I'll be doing the rear o2 first.
Old Jul 31, 2004 | 01:18 AM
Nismo's Avatar
to make things clear, the o2 sim will work for every year max right?
Because I had a 97 auto I converted to 5speed so im using a 95 ecu which is why im throwing the rear o2 code. Hope this will fix that, right?
Old Jul 31, 2004 | 02:24 AM
Jime's Avatar
o2 sim will work for all Max's. Not exactly sure on the 5 spd conversion though why its throwing the code because I am not familiar with it. However get the dual output regardless so you can put it on a 5th gen later if you ever go that route. I believe its the same price anyway.
Pretty simple hookup, the only thing I don't really like is that you have to leave the o2 sensors electrically connected so that the ecu doesn't sense that the heaters are not there. So you have to find some place to stick the sensor (s) so they don't melt any wiring etc. Mine is under the plastic valve cover beside the coils.
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Huttig2009
Sep 25, 2015 03:31 PM
maxinout93
Aug 20, 2015 02:17 AM
silver_i35
Aug 3, 2015 11:20 PM
