blehmco bbk ?'s
blehmco bbk ?'s
I remember seeing somewhere that said we could use cobra rotors with blehmco bbk. If this true( it may not be due to me being a idiot) what specific year mustang is this off of.
Thanks again for the help guys
Chris
Chris
Jeff92SE Has a bracket that you can use for the 13" Cobra rotors, but my set uses only the 12.6" 2004 Maxima rotors. (you think you're going to see a 0.4" difference- I don't!)
Check out my website for details, but I'll be doing some more discounted pricing because of the introduction of my rear BBK... Look for that post sometime today.
I don't think i can see a .4 difference, but i am interested in using these rotors because of the larger aftermarket selection. I would use a 2k4 rotor if you know of one in cadmium and cross drilled.
Yup.. I set up some special .orgy pricing with iRotors on theirs.
http://forums.maxima.org/showthread.php?t=300677
for pics.. for pricing and contact info, see my post #28 in that thread.
Apparently, the 2000+ maximas have a larger bolt hole than the 3-4gens. Teddibear bought a set off me some time ago was supposed to enlarge one set of holes to 12 or 14mm. Then advise if the brackets fit or not. Have not heard from him.
If teddibear's project works, mine will fit the 2000 maximas and will be cheaper. But it's easier to do yours
I've got separate brackets for the 3-4 and 5 gens.. both fit just fine.
Yup. No biggie. The rings help center the rotor much easier then using the lugs. Hey the guy on twinturbo.net tracks his set with his 300z turbo
which have tapered holes to properly center them over the studs anyway....
sure... but the lug stud holes are larger on the cobra rotors too. last thing I like to hear is a huge clunk every time I remount my wheels and hit the brakes. good way to shear off a wheel stud when you slam on the brakes. Ah well... not my ride.
Um.... Haven't exprienced either thing you descirbe. I should know because I've taken everthing off about 3 times to take a look.
Have no idea why you started this anyway. If there's that big of a concern, it was never stated before.
I've seen problems like that with similar projects on other cars. Haven't said anything before because it's not my place, and I don't like saying negative things about someone trying to make mods for our cars. But if it comes down the decision of yours or mine, those are the reasons I designed my bracket instead of just buying yours or making one of my own.
I don't feel the Cobra rotor is a proper substitute on the Max due to those reasons, but if you're willing to run them on your car then more power to you.
not yet. but you will. and soon. and you're going to regret it for the rest of your life.
I'm not saying it's going to be a catastrophic failure in our case, but I've seen it on other cars and I'd be worried that it would happen to mine. It's just not a liability I'm willing to put in front of me.
Please explain why I would experience "clunking" later vs sooner? I don't plan to drive the car any differently in the future.
I didn't know that many car people even run different rotors on thier cars much less you hearing/reading about it.
I just sell the brackets. What people do with them is their choice. I don't sell them in kit form.
Check you pm on the werk forum. I dont' like the direction this is going
wouldn't the problem be solved if you simply rested the rotor on the stud before you mount the wheel so its already pre-set so there is not space for the rotor to "clunk" when you first step on the brake? elimminating the clearance
matt, bout to stop by your house real soon and finally buy this thing. I'm ordering the rotors from irotors next week. should i get just slotted or crossdrilled and slotted? dont know how well they designed the crossdrilled ones. you think those will crack under extreme heat and pressure? also do you have a complete set of front/rear stainless steel brake lines which irotors sells in stock in your dirty garage? =) if you do, how much you selling them for?
sorry bout the laggin.... i will confirm the cobras soon. Its been bought time.. just waiting for my rotors to come in... I've been thinking about puttin a set of the 4 piston 300zx calipers on my rears too and not have a parking break.
Apr 16, 2020 05:15 AM
Matt93SE
Apr 8, 2018 09:23 AM
maxfever1987
Nov 19, 2016 08:01 PM
